Best amp solution for Bluesound. Node plus amp, nad integrated…
Zanollo
I got a Bluesound node And I am currently using with an old receiver ( Yamaha Rx-v2400). I like to upgrade amp. Also, like an amp with zone control or integrated. I also have two speaker pairs,
i figured I have several paths.
1.) get two powernodes
2.) keep my node and add an amp
3.) get a nad with integrated amp and Bluesound like the nad c700 and get a second small amp for satellite speakers
what part would you go?
i did some research on 2 channel 4 speaker amps and found the parasound brand.
BTW. Here are my speaker specs:
Wharfedale EVO4.2
recommended amplifier power: 25-120 watts
sensitivity: 88 dB
nominal impedance: 8 ohms compatible
Mirage Nanosat:
Power Handling: 100 Watts
Recommended Amplifier Power: 10 to 100 Watts
Impedance: 4 Ohms minimum
