Crossover between amps will be active then?so I'll use 3 separate circuits and 3 amps for drive each (HPF-BPF / BPF / LPF)
purifi 400/700/700 amps with DSPsCrossover between amps will be active then?
@thin bLueI have to reiterate this. So far, we have no idea what the actual goal of this speaker system would be. We have no idea of what problem you are trying to solve here.
For example, I am working on a compact, high-efficiency monitor design which incorporates a horn tweeter. That is designed to solve the problem I have of having small listening spaces and wanting a speaker that can fit there, but also play loudly in larger rooms.
My specs for that design were: Point source (or very close to that), high output capacity above 2-400hz, and relatively compact size.
Here, I have no idea what you are aiming for. I don't know if you are trying to build some kind of open-baffle system, or a surround sound system, or whatever else. All I know is that you are apparently asking whether some random 15" driver will "match" some other (seemingly randomly picked as I don't know your intention) drivers.
I can have a terrible woofer, and match it with my KEFs because I know how to integrate it. That's what's important. Getting the integration right matters. There are a million good quality 15" woofers out there. You just need to find the one that fits what you want to do. Do you need bonkers output? Then get a PA woofer that can handle 2000w. Do you want super deep bass? Then look for a woofer with a low Fs and high xmax.
Basically what I'm saying is that there are tons of good drivers out there and the actual implementation matters more than the components you select. The design of the crossover, the geometry of the enclosure, etc. All that plays into how the speaker sounds and makes a much larger difference than the difference between a good B&C 15" and a good JBL 15".
So with that being said: What are your design specs? What is the "problem" you are trying to solve with this speaker? (Where / how are you going to use it, etc)
If you define the design specs, then we can help point you in the right direction.
This reminds me of a time I gave a joke answer to someone on a different forum. They asked for recommendations for speakers for a large festival. Naturally, I answered with a technically correct answer that would have been a really bad idea. (Use a bunch of Danley Jhericos [the ones with basically no vertical dispersion] hung from some helicopters. Then add sufficient MatterHorns for LF duties...)
Here, I am actually trying to help because this forum is quite nice
Doing this passively is madness. Active is the way to go. Sensitivity of the woofer is largely irrelevant then.I've got a couple questions for the DIY'ers now that we are fired up and ready.
- Can I assume that the largest flaw in the passive 4 way design for this case is the large gap in the sensitivity between the 8" woofer ([email protected]/1M) and the rest of the drivers (~[email protected]/1M)? Would you have to attenuate the tweeter, mid, and especially the 15" woofer to match the poor efficiency of the 8" woofer. I imagine a complex network of high watt resistors just for the 15" woofer. This would generate higher than average losses in the amplifier, correct?
Just add a cap as protection and all should be fine.
- I get skiddish with driving a tweeter directly to an amp fed by an active DSP crossover. I've only tinkered with this in software DSP like PeaceEQ from a computer, and this is probably why I'm so skiddish about it. I guess this is just my traditional style of thinking that passive crossovers essentially protect drivers. Though, you can't argue with the lack of phase shift and the 5-20% (or potentially more in this case) power loss of a passive crossover network. I guess a dedicated miniDSP would quell those fears.
Why specifically Selenium? Probably get something with at least 1.4/5” exit, lowest possible extension. Horn wil dictate the rest.
- Any recommendations for a JBL 2216Nd or 2216Nd-1 alternative for a 2-way design with a selenium compression driver?
The trick is to not enter all values. I always enter Qes, Qms, fs,Vas, mms, re, le, xmax and Pe. It will do the rest for you.
- I've found a few sites with TS parameters for the JBL. This is the best I've come up with. I'm sure that I'm missing a few things though, since it doesn't quite work in WinISD.
Thanks. You are right.@thin bLue
Not able to tell you much except for these:
This post is what @sarumbear has been trying to tell you in his posts: You must present your goal for any recommendation to make sense. The best drivers in the best box won't make a great speaker, if you don't know what you are aiming at ...aka "Design Goals"
Yet, you went crude on him.
Not cool.
Out.
Peace
Oh, right! As long as the tuning frequency is below the active range, it's just protection.Just as a cap as protection and all should be fine.
Mainly to keep it "somewhat JBL", but I'm not tied to any specific brand. Maybe I'll start a thread if I get serious about a build.Why specifically Selenium? Probably get something with at least 1.4/5” exit, lowest possible extension. Horn wil dictate the rest.
Thanks! I'll give that a shot. Now the hard part. To convince the wife to let me do the build in the first place.The trick is to not enter all values. I always enter Qes, Qms, fs,Vas, mms, re, le, xmax and Pe. It will do the rest for you.
1.Make fully passive attenuation with 3 drivers make massive heat, difficulties of design, lack of efficiency. match them by Amp gain is much much reasonable and realistic solution for that.I've got a couple questions for the DIY'ers now that we are fired up and ready.
- Can I assume that the largest flaw in the passive 4 way design for this case is the large gap in the sensitivity between the 8" woofer ([email protected]/1M) and the rest of the drivers (~[email protected]/1M)? Would you have to the attenuate tweeter, mid, and especially the 15" woofer to match the poor efficiency of the 8" woofer. I imagine a complex network of high watt resistors just for the 15" woofer. This would generate higher than average losses in the amplifier, correct?
- Any recommendations for a JBL 2216Nd or 2216Nd-1 alternative for a 2-way design with a selenium compression driver? I've found a few sites with TS parameters for the JBL. This is the best I've come up with. I'm sure that I'm missing a few things though, since it doesn't quite work in WinISD.
Good point. I cannot see any reason for a 15” driver on a modern speaker. Amplifier power is cheap. Many manufacturers demonstrated that multiple 10” drivers are perfectly capable for bass in normal size room. You can reach over 110dBSPL at 30Hz with a pair of 10” drivers (Xmax: 20mm).I will once again remind you that 6 cubic feet is larger than most European refrigerators. If I were to do it all over again I would go smaller, better to pass the LF to subs anyway in most rooms and there are plenty of even 10" drivers out there that will reach 30Hz with room gain.
In the words of OP, "big towers with big units make sexy-look aren't they?"I cannot see any reason for a 15” driver on a modern speaker.
Can't argue there.
Can't argue there.
Of course, that's I'm already aware of.I used a miniDSP 4x10 for years to do my active XO and from experience will say you definitely need a protection cap on that tweeter no matter how your system is set up. Even with active XO you still want to match the sensitivity of the drivers and voltage gain of the amps as close as you can to minimize problems, no free lunch.
WOW
Thanks for info!Hello OP @thin bLue,
I hope my multichannel multi-driver multi-way multi-amplifier stereo project thread would be of your reference.
You may find the latest system configuration and various related info as of May 30, 2022 in my post here (#540) on the project thread.
And, please find here (on the project thread) and here (remote independent thread post) the Hyperlink Index of my project as well as some of my related posts on remote threads.
I would also not recommend going passive at all.
If you have the space for 15 inch, it doesn't really matter that much.
Most of any (very) descent 15 inch will perform extremely well, especially compared to any 8 or 10 inch subwoofer.
Make sure the Fs is low enough (< 30-35Hz), Qt is low and they have enough cone excursion (> 6mm or so)
4 ohm is nice to have because of the voltage the amplifier needs to spit out.
The way I would set it up, is just make a nice 2-way system with the tweeter and woofer, ideally with a waveguide, otherwise you will never be able to get a good directivity out of it.
Second is ideally have 4 subwoofers, otherwise 3. If you can set up the two front ones in stereo, that would be ideal, best even in the corners of the room.
Because of this "stereo" approach of the subwoofers, we can move our crossover point all the way up to even 200-300Hz if we really need.
This is one of the best approaches to get low distortion, good directivity (with the waveguide) as well as being able to get rid of those very audible and horrible room modes.
Thanks for great advices for DIY
Of course, I'll use multiple subwoofers to cure in room responses.(Esp. below Schroeder Frequency.)
But big towers with big units make sexy-look aren't they? Acoustical gain maybe marginal, but psychologically.
You can go for 2-way with 15 inch, something like Geddes did.As subs Fully agree with that.
How about 2-way vs 3-way?
2-ways are great!
3-ways can do that as 2-ways do, even with lower THD, but way harder to design.
So I prefer well designed 3-way over well designed 2-way.
