Besign Be-Rca Bluetotth receiver to Topping D30 Dac connection?
promisedave
Hi, I"m trying to send my music signal From a Besign Be-RCA wireless Bluetooth through a Topping D30 Dac then into my stereo.
There's optical in and usb in on the D30, but the BE-RCA only has RCA out. Therefore I have to use an RCA to Usb female cord then plug the Topping factory USB cord into it.
The DAC isn't recognizing the input signal from the Be-RCA, but it works when i plug the factory USB right into my computer. It sounds amazing and I don't want to have to return it. Do you have any knowledge of how to get these two to work together?
NTK
US East
Welcome to ASR.
Your BE-RCA Bluetooth receiver is already a DAC — it outputs analog signals. It was designed to connect to your stereo amplifier directly. The BE-RCA works independently from your Topping DAC. You should connect your BE-RCA and Topping to separate analog inputs of your stereo. If your stereo only accepts 1 analog input, then you'll need a switcher.
promisedave
promisedave
Thanks for the help. I was hoping to upgrade the pretty poor dac in the be-rca, but it sounds like that's not an option...
NTK
US East
Yep. Unfortunately, there is no upgrade path to your BE-RCA. You can replace it with something like a Topping BC3, but I don't know how "bad" the DAC in the BE-RCA is, and if there is improvement, whether it will be readily noticeable.
http://www.topping-audio.com/productinfo/518541.html
