PristineSound
Also, keep in mind, for every 3dB SPL increase, you need to double the amplification power.
I want to reassure everyone here that you cannot tell any difference between a Hypex, Purifi and AHB2, level matched. I have both, the AHB2 and Hypex, there are no audible differences. In fact, with most competently designed amps, there is no difference.
Yes. IF an amp doesn’t have sufficient protection when it clips it can damage speakers. These are all well known factsYou are 100% correct. Not a lot of people know, but the AHB2 has a myriad of protection mechanisms - hence another reason why it is the best amp of all time.
From the AHB2 manual.
Though, I gather others here are talking about other amps that's being pushed to clipping. However, merely being underpower without pushing your amp to clipping will NOT damage any speakers.
Even better: if you want something to sound twice as loud, you need 10x the power (10dB)!Also, keep in mind, for every 3dB SPL increase, you need to double the amplification power.
Actually it's not dumb at all. The peaks are going to look almost like a random variable. Finding the absolute peak in an entire recording and adjusting the loudness to avoid that little peak clipping would be pretty hard to do.Yes. IF an amp doesn’t have sufficient protection when it clips it can damage speakers. These are all well known facts
What’s interesting here is the AHB2 actually ALLOWS “occasional clipping” but when it senses whatever threshold it vaguely deems as “severe overdrive” it goes into a handicapped limp mode and must be restarted. To me that’s a bit dumb.
This silliness of a topic has been talked to death. I'll let others talk to this.There is no way anyone could claim that all amps (presumably within a given price range) sound the same – they just don’t, whatever their measurements may suggest. I liked the Benchmark in most respects, but not the way is delivered music. For me, this is the sole reason for choosing one amp (or more so one speaker) against another.
Since he didn’t specify the level. I would pick the level at which the AHB2 experiences clipping and even “severe overdrive” whereas the more powerful amps would still sound normal
Well done, you said everything I would like to say but only more elegant.Actually it's not dumb at all. The peaks are going to look almost like a random variable. Finding the absolute peak in an entire recording and adjusting the loudness to avoid that little peak clipping would be pretty hard to do.
And if you play vinyl LPs--fuggedaboutit. One scratch will make a max-output click that will clip any amp if the music is at near its linear capability.
Clipping adds unwanted harmonic content--more high frequencies. Voice coils in tweeters can either handle it or not. But those high distortion peaks won't be any louder than the main signal (in terms of voltage that is insensitive to Fletcher-Munson--hearing is another matter), and any decent speaker should survive it just fine if it's kept within reason. Eventually, enough high-frequency content gets into the steady state that it can overload and overheat the tweeter voice coil, but that doesn't happen on short transients, clicks, and pops. (It can easily happen in just a few seconds playing a sustained top-octave signal like a sine wave at maximum power.) Most pros will look for the point at which the clipping indicators flash for very short periods occasionally--LED's are faster than voice coils. I rather doubt that at the listening levels associated with those occurrences anybody will be able to detect a few milliseconds of clipping, or at least be sure what they are hearing is the amp and not their ears.
But if even sustained harmonic distortion at lower frequencies cooked speakers routinely, no guitar amp these days would still be breathing.
So allowing occasional flashes of clipping but going into protection on sustained clipping sounds about right to me.
Rick "if it sounds bad, turn it down" Denney
