Behringer UMC204 Headphone Gain mod
Lambda
For so reason the this interface is designed in a way has way more Analog gain than it can Handel
Since everything is powered from 5V with a 2,5V virtual ground it can relay only output about 1Vrms
1Vrms corresponds the volume potentiometer at 12 o'clock. everything over this will result in clipping.
I don’t like this so i changed it:
To:
By removing the 10K resistor and replacing it with the 1,8K the output Gain 6.5 to 1
Originally wanted to swap the the 10k and the 1,8k to get a max gain of 1.1 this is not needed the op amp is unity gain stable.
