Greetings from Korea.
I am writing this post to share my experience modifying speakers.
Please note that this text was written using a translation tool, so there may be some awkward phrasing.
I am an engineer from Korea with 17 years of experience.
I have always aspired to own a high-quality monitoring system. I began this project two years ago and, just a few days ago, finished tuning the system to a level that meets 90% of my expectations.
I have been using Behringer B3031A speakers for over a decade.
Over time, the components aged; the woofer surrounds tore, preventing proper sound reproduction across certain frequency ranges.
To address these issues, I decided to embark on this project, balancing financial constraints with my curiosity about electronics and science.
I will set aside the discussion of just how worthwhile these modifications are for now.
Some might ask, "Wouldn't it be better to just buy a good pair of speakers?"
However, as I mentioned earlier, I embarked on this project while trying to strike a balance between financial constraints and scientific curiosity.
I simply hope this serves as a useful reference for all of you.
I don't have any frequency response data measured with a measurement microphone after the modification, as I lack the necessary equipment. Instead, I focused on precise calibration using an oscilloscope and then fine-tuned the sound to my personal preference.
I hope to delight your eyes with as many photos as possible.
All right, let's get started.
This is the original state.
One day, I discovered this: the speaker's surround was torn, preventing sound from being output correctly within a specific frequency range.
This is what the amplifier looks like in its original state.
You simply need to remove the six screws on the back.
I am already quite dissatisfied with what I see here.
For starters, the circuit board looks very messy because the flux wasn't properly cleaned off after soldering.
Rather than going through every single component I replaced during this modification, it would be quicker to list the ones I kept as-is.
First, I retained the original tweeters.
As for the amplifier components,
I kept the optocoupler labeled "OP1" (LT9914) on the PCB, the three TDA7293 chips, and the two diodes marked D5 and D6 (which serve to prevent reverse current in the voltage regulator, and it's 1N4148).
Aside from those—and a few specific op-amps, SMD resistors, and capacitors—I left everything else unchanged.
I did replace a few SMD resistors and capacitors, but I’ll explain the details later.
Thank you!
Please note that the 6800µF 50V capacitor is secured to the bottom with adhesive.
This photo shows the circuit board after almost all components have been removed.
As previously mentioned, a few components remain. The only components not removed in the photo above are diodes D5 and D6 (1N4148),
optocoupler labeled "OP1" (LT9914).
However, the final version to be released later will include all of the following components:
—Voltage regulators (2 units, 7815,7915), R1, R2, R3, R4, VR1, VR2, VR3, and VR5 have been replaced.
This photo shows the circuit board after the components have been removed and the flux cleaned off.
Having experienced firsthand just how detrimental flux residue can be to sound quality,
I recommend always checking this area and cleaning it thoroughly whenever you purchase a new device.
The leads of the yellow film capacitors are made of ordinary iron rather than tinned copper.
I believe this was an unavoidable choice driven by cost considerations.
Sound quality is determined by the accumulation of subtle differences,
and I consider replacing these components essential to achieving a sound that aligns with the "design intent."
One of the components I dislike is the very cheap ceramic capacitor.
I replaced the ceramic capacitor in the high-frequency EQ adjustment section on the back of the speaker with a mica capacitor.
Additionally, I replaced the original adjustment component with a 25-turn potentiometer because the existing one lacked sufficient precision. (The 25-turn potentiometer is shown in a different photo.)
The transformer output is converted to AC +30V and AC -30V and then rectified using four diodes.
In this process, the quality of the diodes is crucial.
The diodes used are
Vishay SBYV28-200,
which feature a very fast trr of 20 ns.
I don't have a photo, but I replaced the cable with Belden 5000UP. To facilitate disassembly and maintenance, I reused the existing connectors and secured them using a crimping tool.
The cable is thicker, so I made the hole at the back larger.
I need to talk about the Port-Hole.
The heat-activated adhesive holding it in place might come loose.
I’ve moved a few times.
And it seems to have loosened up as a result of that movement.
But more importantly,
the port itself has its own unique resonant characteristics.
If you take it apart and tap on it,
the pitch varies depending on the location.
So, I handled it like this using a rubber band.
I originally intended to use this thin exercise band by attaching it with adhesive, but it didn't work well because the adhesive strength was weak.
Dayton Audio RS225P-4A
Although the Dayton Audio RS225-4 is slightly more expensive,
I chose the Dayton Audio RS225P-4A because its wider frequency response range seemed more advantageous for adjusting the crossover point.
I had to align the existing screw holes on the speaker enclosure with the holes in the plastic front cover.
So, I used a drill press to drill holes along the edge of the woofer. Unfortunately, I don't have any photos of that process.
This can be considered the first version of the amplifier.
Many of you might be disappointed when you see this photo... but I had no other choice.
I never imagined the leads would stick out of the board like that!!!
You can also see the voltage regulator from before it was replaced.
Receiving input signals through such a thin cable is unacceptable.
I assembled the connectors using Neutrik connectors and Canare L-4E6S cable.
I fabricated the terminal using tinned copper wire. Then, I secured it using "Mix & Fix."
I replaced the adjustable variable resistor with a 25-turn model and soldered jumper cables to measure the resistance.
The jumper cables were also selected from non-magnetic materials.
I replaced two capacitors and four resistors in the input stage; it appears the photo was taken before these replacements were made.
To extend the high-frequency response, I replaced the 100pF capacitors with 20pF.
While one might consider this futile given that high-frequency attenuation occurs later in the circuit,
I made the adjustment because I determined that the original design excessively attenuated high frequencies out of concern for RF interference.
Additionally, I replaced four 10kΩ resistors with 20kΩ resistors to increase the input impedance.
I decided to use jumper wires for the installation because replacing the 6800µF 50V capacitor with a 10,000µF version created a height clearance issue inside the amplifier case.
I would like to thank those who pointed out the things to watch out for regarding this matter in other posts.
I replaced the component with a high-quality adjustable voltage regulator purchased from AliExpress and attached a copper heatsink.
Kapton tape has been applied beneath this copper heatsink to prevent short circuits.
The product I received was different from the photos in the AliExpress product description.
A "Bourns" trimpot was used for the voltage adjustment of this constant-voltage regulator.
The output voltage is set to 15V. Although it could be raised to 18V—the maximum operating voltage for the op-amp—
I decided to keep it at the standard 15V, as increasing it would offer no practical benefit for this amplifier.
The film capacitors at the rear include capacitors designed to reduce ripple during the smoothing process,
as well as capacitors connected in parallel with the non-polarized coupling capacitors.
I believe that connecting the non-polarized capacitors and film capacitors in parallel has resulted in improved high-frequency response and a more transparent sound.
If we divide the amplifier circuit board into the "power section" (above the voltage regulator) and the "signal section" (below the voltage regulator):
I replaced all the electrolytic capacitors in the power section with low-ESR capacitors from Panasonic & Würth Elektronik. Previously, they were allmost Nichicon capacitors & others.
During this process, I removed all the film capacitors, verified their polarity using an oscilloscope, and reinstalled them in the correct orientation.
You might be wondering about the addition of two 25-turn adjustment potentiometers.
"6" is a trim pot that adjusts the high-frequency Booster Frequency (Not A "LEVEL"). (set to 17 kHz (I'm not SURE) at the Factory Fixed, but I changed it to 20 kHz.)
"7" is a trim pot that adjusts the crossover frequency.
VR1 - Tweeter Booster Frequency Level
VR2 - Tweeter Level
VR3 - Woofer Level
VR5 - Woofer Booster Frequency Level (Factory Fixed: 40Hz & I'm not SURE) (The B2030A and B2031A do not have a VR5 trim pot.)
(VR4 in the B2031A's circuit diagram corresponds to the user-adjustable "Input Trim" knob.
On the B3031A's amplifier as well, the PCB labels this Input Trim component as VR4.)
By measuring the Vpp with an oscilloscope while varying the frequency, I confirmed that the crossover point of the modified crossover is 1.9kHz.
Crossover points for ribbon tweeters are generally set to a somewhat higher frequency than those of other speakers.
This is because excessive strain can be placed on the tweeter as the volume increases.
The default crossover frequency for this speaker is 3.2kHz.
Since there is a limit of 35 photos for uploads, I will provide an explanation instead.
I set up the jumper cables that way to measure the resistance.
Also, please keep in mind that having the same resistance value doesn't guarantee that the sound quality of the two amplifiers will be exactly the same.
Please make sure to remember this important point.
Anyway, thanks for watching.
I'll post photos of the finished result in the comments.
Thank you very much!
Thank you!
The diodes used are
Vishay SBYV28-200,
VR2 - Tweeter Level
VR3 - Woofer Level
