Beginner with EQ. How do I EQ the Amazon Music App?
John_M
FYI I cancelled Amazon and got Tidal instead so I could use UPP. Working fine now.
AdamG
Moderator
Reality
This is a blatant lie. I just spent 10 minutes looking, wondering how I missed it.
Welcome Aboard @HarryBalsagna. Your first post out of the gates and you accuse a Member of a blatant lie. We don’t talk to each other like this. You have used up your one and only free pass.
shaney777
Any updates here? I need to use PEQ with Amazon Music HD and a Chromebook.
Pugsly
I know OP said they were running a PC and wanted free, but if you have a Mac and are willing to pay a little, I highly recommend SoundSource. It allows for easy system-wide EQ, has built in headphone EQ settings for lots of popular headphones, and allows people to very easily add VST plugins. I have no connection with the company or creator, btw, just have found it an excellent and very easy to use program.
HorizonsEdge
I use an app on android called "wavelet". It has EQ for ~15K ear/headhones and brings them to the HK curve. You can also make your own.
On PC, I endorse peace+equalizerAPO. Good tools.
shaney777
Am I correct that Wavelet does not work with Amazon Music HD?
shaney777
I really wish there were a solution for this! As an android/Amazon Music user, I have no way to apply Amir's recommended EQ curves!
It's terrible! I am going to try out a Russian app that I found in the Play app store.
Jimbob54
You are not.
Ohhh, they have updated wavelet so it can pick up amazon in legacy mode. Thats new! (Though just noted I get glitches)
Still doesnt work in "new" mode for me though.
shaney777
Is it a solution or no?
shaney777
