Welcome Aboard @HarryBalsagna. Your first post out of the gates and you accuse a Member of a blatant lie. We don’t talk to each other like this. You have used up your one and only free pass.This is a blatant lie. I just spent 10 minutes looking, wondering how I missed it.
Any updates here? I need to use PEQ with Amazon Music HD and a Chromebook.
On a Chromebook? You are likely to be out of luck for quite a while, I think, unless Amazon adds EQ functionality (back) into Amazon Music.I really wish there were a solution for this! As an android/Amazon Music user, I have no way to apply Amir's recommended EQ curves!
Am I correct that Wavelet does not work with Amazon Music HD?I use an app on android called "wavelet". It has EQ for ~15K ear/headhones and brings them to the HK curve. You can also make your own.
On PC, I endorse peace+equalizerAPO. Good tools.
It's terrible! I am going to try out a Russian app that I found in the Play app store.I really wish there were a solution for this! As an android/Amazon Music user, I have no way to apply Amir's recommended EQ curves!
You are not.
Is it a solution or no?Ohhh, they have updated wavelet so it can pick up amazon in legacy mode. Thats new! (Though just noted I get glitches)
Still doesnt work in "new" mode for me though.
It's free to trial so give it a go. Think the experimental settings may work.Is it a solution or no?
Thank you!It's free to trial so give it a go. Think the experimental settings may work.
