Happy Holidays :=)
Thanks for the forum, all the reviews and comments
I've read some of them (even the beginner's guide) but some things I do not understand and for some, the more I read, the more confused.
So I simply ask for an explanation- and buying advice.
Current setup for stationary desktop use:
- headphone Hifiman Sundara (Frequency Response : 6Hz-75kHz, Impedance : 37Ω, Sensitivity : 94dB)
- internal soundcard asus xonar essence st
asus xonar st specifications
The sound card has 3 software-gain settings: Normal (< 64 ohm)s, High (64 - 300 ohms), Extra (300 - 600 ohms)
Windows slider 30 - 40 % on normal is enough for me to be loud (I've still good ears), with the other two it's 10 - 20 %.
I really like that the sound card has internal asio drivers; possible to get a DAC with something like that too?
My budget limit would be 250 € for both dac and amp.
I though about buying the usual recommendations I read here about, but I'm not sure:
- The hifiman sundara can even be used with a smartphone - do I even need an amplifier?
- If I need both: Spend more money on the DAC or the Amp?
- In this review I'm confused about the statement "output impedance 5,9 ohms); is that of any concern or only for dynamic driver headphones?
review aune x1s
The new Aune X1S 2020 version is said to even have 10 ohms!
The same goes for the Topping DX3 version 2, ~ 10 ohms.
I'm really not sure what to buy. Please explain the questions and buying recommendations would be nice too
I plan to use the new setup for years to come and will not go back to dynamic driver headphones.
If the recommendation is really really good, it might be even just a bit more pricey.
Thanks in advance.
