Hello Community,
Hope you are all well & safe!
I postponed the living room setup (old post) for the time being as it's not financially reasonable for me. However, considering now a first setup for my bedroom (~17sq.m) as I spent most of my time there when at home (home office, etc.).
Please see in the table setup options I am considering based on budget ~2500-3000€. Many people recommend the LS50meta instead of the Wireless II as is avoided the single point of failure. Furthermore, separate box allows to upgrade setup at later point if desired, though highly doubt will be needed.
I think this is a decent first setup, do you agree? Which option would you consider best based on value/ benefit?
P.S 2 price options for the KEF LS50 Meta from the same reseller, i.e. 544€ (demo I assume) and 1050€, should I be really concerned about a demo model? I will be happy to save 50% if possible.
Looking forward to your opinion/ recommendations!
Thank you,
Metodiy
Speaker | Amp | Sub | Price |
KEF LS50 Meta (544/1050) | WiiM Pro (410) | KEF KC62 (1500) | 2454€ |
- | WiiM Ultra (588) | - | 2632€ |
- | Marantz M1 (900) | - | 2944€ |
- | Pro | SVS SB1000 Pro (850) | 1804€ |
- | Ultra | - | 1982€ |
- | M1 | - | 2294€ |
KEF LS50 Wireless II (1653) | N/A | N/A | 1653€ |
- | N/A | KEF KC62 (1500) | 3153€ |
- | N/A | SVS SB1000 Pro (850) | 2503€ |
Thank you,
Metodiy
