Battle of RCA Cables: Mogami, Amazon, Monoprice
I maybe late to this but for you UK guys that want Mogami, Belden, Sommer by cut lengths at very reasonable prices try my local supplier Designacable, Beeston, Nottingham they have a website.
My favourite is Sommer SC Spirit LLX for unbalanced RCA @ £4.24 per metre. I've also used Mogami,Van Damme and Belden. They do cheaper types and dearer types i have played around making up several leads just for the fun of it for both digital coax and analog interconnects.
They also do a range of plugs plus silver solder if you want to use that.
They will post or you can collect as i do, there only a few miles from where i live.
ps I've no connection with them just a small customer, They do make and supply to a lot of the best bands on this planet you can see there list of customers who use them.
Well, at that price you know for sure they're not using silver wire....
I would bet any reasonable amount of money that they use copper; why would they use anything else? Aluminum is a pretty good electrical conductor, but why would they use aluminum? It would probably be special order / more costly to source for the conductors used in these cables, so they wouldn't do that. Aluminum would work, but there would be no advantage to it, except to save a few grams per cable in weight. And these are not aerospace cables.... and they wouldn't use steel, that would be crazy and would dull their tooling.
And more likely than not, the core is stranded. Why don't you buy one, cut it apart, and let us know? They are not expensive - c'mon, sacrifice for Science!
I did just that i wanted 2 x 3mtr coax for a pair of active subs Amazon were out of stock of 3mtr so i bought the 7.5 mtr amazon basics coax and cut into pieces 2 x 3 mtr and a couple shorter ones for CDT to DAC
They were Aluminum center core with white teflon over it and what appeared steel woven type braid over that with softish pvc outer.
Didn't like the short ones for digital use. The 3 mtr ones are still in use on the subs there fine.
You're getting fucking ripped off over there on the island, mate.
And what should the cable cost in the UK?
The importer has to pay for increased transport, customs clearance, duties, and taxes. They have to calculate these costs based on the quantity purchased, have to invest in full reels, and storage space costs money, as does the employee who goes into the warehouse, cuts off a piece, and packages it.
And if it goes through an additional retailer, it gets even more expensive.
And each of them has to cover their costs and make a profit.
Alternatively, you can certainly order the cable within the EU.
Add to that VAT, import duties and postage hmmm dont think so
Its still cheap as chips cant buy a decent coffee for that here
Ripoff Britain, innit?
Even if you order 10 meters of this cable directly from the UK from this very cheap retailer, you'll still end up paying £3.95 per meter, which, with taxes, is at least £4.75 per meter.
On top of that, there are the customs clearance fees from the shipping company and possibly customs duties, though these won't be a significant factor.
For normal quantities, a price below £5 per meter, including all costs, from a cheap EU retailer is unrealistic.
This begs the question: where is the rip-off happening?
Und bei größeren Mengen bietet der britische Einzelhändler/Importeur möglicherweise sogar einen Rabatt an.
Did you get any? What length are you looking for? I've just remembered that I've got 4 pairs of QED Qunex 2, 1 metre, that I don't use anymore.
Not yet, no. Following the good advice here from @Ropeburn, I looked into music shops online and think I've found what I'm after from Gear4music at really good prices.
Thanks for the thought on the QED, but funnily enough, it's a pair of those that have failed on me when I took them out of my cd recorder to put in my newly acquired Tascam CF card recorder. Mind you, they are over 20 years old, so I shouldn't complain really, lol (see pic).
Cables rarely fail as such. Most likely, it's just the connection to the plug(s). Was it one or both? I'm sure a couple of minutes with a soldering iron is all that's needed.
Funnily enough, I recently bought a Tascam portable recorder, although it uses µSD not CF.
It's just the one pair. They were working fine in my cd recorder for years, but removing them to put in the Tascam they stopped working. I dug out another old stock RCA cable and put that on along with one of the QED and all works fine now.
Hence I need another double pair of RCA's for the cd recorder.
Be glad it does. :D CompactFlash... ugh.
The compact flash has been working great, although it's definitely quicker to rip albums with my cd recorder than faff around with Audacity. It's handy for doing my 12" singles in batches though.
Another kind poster on here put me onto a CF to SD card adapter, so if push comes to shove I'll go down that route, but no need for now.
