Bass Reflex On Studio Monitors Covered By Ultimate MS 80B Stands
OskiB
Good Day!!
Is this blocking the bass reflex too much to completely affect and change the sounds on this monitors ?
What would You recommend ?
Thank You Very Much!!
Welcome to ASR, @OskiB!
No issues at all regarding port blockage.
If anything, you'll have some unnecessary edge diffraction off the protruding platform.
Is there a reason you're not using the two M6 threads on the back plate for mounting?
Welcome to ASR . . Thank You Very Much!!
Do You Mean This
Yep.
If the OP is able to mount the speaker backwards and then rotate the stand 180 degree there is a chance to prevent edge diffraction.
Yep.
Hallo!! Thank You!!
I got this MS 80s because I need them to be angled . Stands too high .
Yes for example, but you have options:
This is great!! Thanks for the advice!! . I hadn't thought about it . I'm using the stands I currently have . : ) : )
Yep.
Thank You!!
That's great advice . I need the monitors to be angled . Stands too high . : ) : )
