Ultrasonic
I will not do that! I want hidden subwoofers.
Fair enough
If you're fine with only <50 Hz, sure.4th order bandpass would give 3dB extra headroom. I know this is theoretical, but am I right in my assumptions?
But if I pull down everything above 20hz (I can use op to 10 bands of PEQ for each sub), I can get past 50hz? For example, in your graph the output at 20hz and 90hz is the same - 95dB. I don't say, that the output quality would be the same for sealed vs the bandpass at 90hz, but if I EQ things, I could get maybe to 70 or 80hz in bandpass? I get that the roll off would be very steep that way and the integration could be difficult, but I'm not sure I can know that without trying.If you're fine with only <50 Hz, sure.
That will give you just more output if the volumes scale with the amount of woofers. Given the same diameter, it just means more air must go through it, leading to possible scuffing sounds and more distortion.@voodooless For the 4 woofers I used 200L for the sealed part and 100L tuned to 30Hz in the vented part, for my sim in WinISD. What would the result be if you simulate that in BoxSim?
2 woofers with both enclosures half the size, tuned to the same frequency could work out nicely if WinISD gives somewhat accurate results.
I mean when using the 2 instead of all 4 woofers, but halving the enclosure volume (compared to the 4 woofers) would result in the same transfer function only reduced in amplitude. Right? It looks quite nice in WinISD. And the 2 woofers would reduce the air velocity in the vent drastically.That will give you just more output if the volumes scale with the amount of woofers. Given the same diameter, it just means more air must go through it, leading to possible scuffing sounds and more distortion.
Why would they? Same airflow for same SPL I would assume.And the 2 woofers would reduce the air velocity in the vent drastically.
It doesn’t model port airflow, so can’t tell you.How does that TF look in BoxSim?
Right, I forgot to adjust for equal SPL after removing the 2 subs from the simulation.Same airflow for same SPL I would assume.
Great you pay $40k so you can hear aircon rumble and semis going by outside the studio in bad recordings that should have filtered those out. Theres no music below 20hz, with one exception, 32' pipes. And even with a pipe organ those low freqs. are usually reduced or eliminated because they need high levels and that makes mixing/mastering difficult. Imagine how quickly a tone arm with a 10hz resonance will feedback while your room shakes from the turntable rumble from one of these. Even movie LFE tracks have very little below 20hz because they dont need it.This reminds me of TRW-17 rotary subwoofer, learned of it few days ago thanks of ASR :
Eminent Technology TRW-17 Rotary Subwoofer
And now for something completely differenta subwoofer that looks like a fan and can reproduce frequencies down to 1Hz and below. Yep, you read that right1Hz and below. Developed by Bruce Thigpen and available from Eminent Technology, the Thigpen Rotary Woofer Model 17 (TRW-17) breaks entirely...www.soundandvision.com
1Hz-20Hz![]()
Your sealed section shows 40L in your sim.26.5ltr sealed section, 23ltr ported section, 125mm pipe diameter and 1.3m pipe length.
I know, but I've just calculated the volume of the boxes I have right now, and they are 26.5ltr. It would make this experiment way easier, if I can just use existing boxes without big punishment for them being smaller. WinIsd simulations equalized by Xmax at 20hz, 70w for 40ltr, 90w for 26.5ltr (purple):Your sealed section shows 40L in your sim.
I was wandering the same thing from the beginning. I just have no background or deep understanding off acoustics, hence this thread. I was even looking for some 300mm>x>125mm adapters just to try something.Interesting setting.
Some reflections: High- and Middle Tone compression drivers are all around.
What about low frequencies compression concepts?
If one driver, larger than than the whole in the wall, was used, close to the wall, what would be the result in FR in the room and what would be the optimum of enclosure in the back of the driver?
Very interesting. The way I see this:
At 10hz, the output is almost identical - around 78dB. At 20hz, bandpass pulls ahead with 95dB vs 92dB. Sealed goes to reach higher SPL with 110dB vs 105dB. So, if I cut anything below 20hz and equalize everything above to be flat to 20hz level (which means pulling down everything above 20hz), 4th order bandpass would give 3dB extra headroom. I know this is theoretical, but am I right in my assumptions?
You're right, and I get it. It's just that SPL is one of the few metrics I can reasonably understand, everything beyond that I have to physically test, to see how it works. I will try to make some "mock-up" 4th order band pass box this weekend and compare it with the sealed box in similar location. I will try to do some REW measurements.You’re probably right, however the sealed, IB and bandpass all have different transient response and group delay behaviour.
If you are playing some steady state sounds the SPL is probably the most important.
If you are playing something that is more impulsive, then SPL may not be the sole metric to be looking at.
I think that some of the box design S/W packages give the group delay.You're right, and I get it. It's just that SPL is one of the few metrics I can reasonably understand, everything beyond that I have to physically test, to see how it works. I will try to make some "mock-up" 4th order band pass box this weekend and compare it with the sealed box in similar location. I will try to do some REW measurements.
I don't use a HPF. But I very rarely listen to content that contains 10-20Hz with significant amplitude (although it's pretty funny).I usually put high-pass at 20hz for protection
