- Joined
- Jun 10, 2018
- Messages
- 6,233
- Likes
- 9,361
Nearly all active sub woofers come with a control to roll off the sub at frequencies from around 35 hz to 120 hz (it varies). I am wondering about different ways to roll off the mains, or if that is even needed.
1. Consumer AV receivers will roll off the mains and even have a sub out to roll off the sub. I suspect they don't measure well.
2. I am using a Crown XLS 1502. It has a high pass filter which is variable. The disadvantage (if you want to call it that) is it measures a lot worse than a Hypex based amplifier. However, a lot of folks get good results with these. This amplifier has been reviewed here at ASR.
3. ASR member @mitchco wrote an article published at Audiophile Style on how to use Audiolens to fashion a crossover in software. I don't totally understand how to put this together. My take is it is a very high performance approach.
4. MiniDSP makes some combination DAC, crossover, room EQ hardware. Prices start at $205 for the 2x4 HD. It has been reviewed at ASR. It has a 90 db SINAD which isn't all that great. If I wanted to upgrade my Crown to a Hypex, it would be a waste to use it with this DAC. MiniDSP makes a much nicer unit, the SHD with Dirac and Volumino built in. It's only $1200, but they will throw in their calibrated microphone because they are so nice. The SHD has been tested here at ASR.
5. I wonder about the viability of not rolling off the mains at all. I don't believe this is a good alternative with speakers like the LS50 which I have now, or nearly all 2 way bookshelf speakers. However, with tower speakers having significantly better power handling I wonder if this would get good or great results. There aren't any tower speakers I am in love with right now, either.
6. Some of the active speakers have bass management built in. The LS50W even has a sub out connection. For $2200 I consider it a possibility. My LS50's could be sold or given to a relative. If I wanted an upgrade this probably makes more sense than buying an SHD plus a Hypex amp.
Any comments on the viability or preference for any of these solutions? It's not just about what I might do, but what some of the brain trust around here thinks about the general problem of rolling off the mains.
