Clipping of the low frequency signal somewhere in the chain is a real problem, and care must be taken to ensure this does not happen. This is a solved problem, it is known. Still, I can not see that this issue is tested for in the processor/avr reviews here on this site.
Sub out from processor/avr is the input signal to the bass-system, and in a decent cinema system, this system is designed for both full frequency range and necessary output capacity, which is >125dB.
LFE is +10dB which ends up at 115dB for 0dB. This does not mean that the sub out must handle 10db higher voltage, it just means that for a 0dB signal the spl from the bass-system should be 115dB. So the requirement for output voltage is no different from other channels.
The problem is when bass from other channels is routed to the sub channel, and added together. In total, a full worst case signal ends up at 125dB for 7.1. This means there needs to be an additional 10dB headroom in the chain to ensure no clipping occurs. You would think the manufacturers have full control of this, after all, it is not that difficult to get right. On the other hand, in a business where a power cable is claimed to improve sound, well, who knows. And indeed, it turns out this is a problem in MOST processor/avrs's, and for some it is possible to fix it by choosing a proper gain structure,
First possibility for disaster is clipping the signal digitally when summing the bass inside the dsp. Then there is no salvation, the signal is destroyed.
Then there is the possibility of clipping the sub out. This is possible to avoid with proper trim level settings and gain on the bass system.
I use Denon/Marantz in my systems, so I can provide information on how they work and how to avoid clipping on those, perhaps coming later.
