Pdxwayne
- Joined
- Sep 15, 2020
- Messages
- 3,219
- Likes
- 1,172
- Thread Starter
- #41
I see. I will use 96KHz to capture and see how it is.How did you adapt RCA to the Solo's balanced input? Monoprice RCA --> XLR cable? You may want to temporarily resort to battery operation on the laptop in order to defeat any ground loop issues.
I think Audacity uses WASAPI by default these days, but it's shared mode and as such settings for the recording device have to be explicitly chosen (the control panel dialog has gotten even more hidden since Windows 10 but is still there). Format might default to 16/44 for all I know.
In the CS4272's ADC as used in this device, digital filter stopband at single speed starts at about 0.58fs, so you really want to run that at 48 kHz at least (no aliasing until 0.42fs = 20.2 kHz). I would recommend 96 kHz (stopband from 0.68fs --> no aliasing until 0.32fs = 30.7 kHz). 192 kHz probably is diminishing returns territory (stopband from 0.78fs --> 0.22fs = 42.2 kHz, though ultimate rejection is a few dB better still).
BTW, in controlled listening tests level matching to 0.1 dB is advised. 0.3 dB is about the limit of human perception. A mismatch of 0.5 dB probably won't cut it.
I was using the right channel of Scarlett Solo today when using Reaper and got very bad loopback noise (noisy even when laptop in battery mode). I switched to left channel, using RCA to XLR adapter from DAC, then it is a lot quieter.
Yeah, the E30 is about 0.7db louder than X16 when using same db setting on each DAC. So, even if I adjusted E30 db 0.5db lower, it is still about 0.2db louder.
Thanks!
