In Toole's book Ch 8.4 "Stereo Bass: Little Ado about Even Less" he dismisses the idea on two grounds: (1) psychoacoustic studies which shows the effects are either subtle, require trained listeners, or do not meet audible thresholds, even with contrived test signals; and (2) recordings, especially recordings mastered for vinyl, do not have stereo bass anyway.
In the spirit of open-minded investigation, I am prepared to put aside point 1 and accept the findings of Griesinger and Lund. So I investigated point 2 - do recordings contain stereo bass?
I decided to do a null test in Audacity. I invite ASR members to criticise my method -
if there is a flaw in my reasoning or my method, I would like to hear about it. I started with a CD rip of a
mono recording - a 1929 recording of Artur Schnabel playing Beethoven piano sonatas, remastered on digital by EMI in the 1980's. The intention was to confirm that the method works. This was my process:
1. Open the recording in Audacity
2. Split the stereo track into two mono tracks by clicking the down arrow and select "Split Stereo to Mono" as shown above
3. Select the second track then invert it with Effect - Special - Invert
4. Select both tracks with Ctrl-A ("select all")
5. Combine both tracks with Tracks - Mix - Mix and Render to New Track
6. Here we see a nicely nulled mono track, confirming that the operation has worked. Now select "Spectrogram" from the down arrow. Hovering the mouse on the vertical scale (the cursor will change to a +) we select 0Hz - 120Hz to zoom in.
7. Result. Anything black = nulled out. Anything coloured = contains sound energy.
So why does a 1929 mono recording have decorrelated bass below 40Hz and down to 0Hz? This particular remaster came from 78's. If you listen to the recording, you can hear clicks and pops from vinyl playback. I am convinced that the decorrelated bass is an artefact of the remaster, perhaps from rumble from the turntable, warped disc, or something. Indeed, if you zoom in you can see a regular periodic repeating band between 30-40Hz. I am not sure what that is, 78rpm should be 1.3Hz.
Regardless, I repeated the experiment by splitting the stereo track into mono and deleting the second mono track. I duplicated the first track then inverted and nulled it. The result (as you would expect) was a perfect null - black screen.
Anyway, now that I have come up with a method to examine for stereo bass, I analysed some of my other CD rips. I found that
all of them did not null below 100Hz. In other words,
every recording I looked at contained stereo bass.
For example, this is Hugh Masakela's "Stimela", a well-known audiophile favourite. We can see some areas of nulls, especially below 40Hz. You can see why audiophiles like it, there is no compression so it is not a victim of the loudness wars.
And this is Michael Jackson's "Wanna Be Startin Somethin" from "Thriller". In contrast, this track was mastered much louder so there is a lot of digital clipping (exceeds 0dB). Once again, the spectrogram shows decorrelated bass between 0Hz - 100Hz.
So - is this evidence to dismiss Dr. Toole's 2nd assertion - that recordings do not contain stereo bass? Of course, I would have to look at thousands of tracks for real evidence, and so far I have only examined half a dozen. But it's a 100% hit rate so far. I am always sceptical when I get an unexpectedly good (or unexpectedly bad) result - it tells me that my method is likely to be wrong. To validate this method, I should be examining a vinyl rip, but I can't think of any recordings off the top of my head.
