Sokel
- Joined
- Sep 8, 2021
- Messages
- 11,865
- Likes
- 13,240
The implication goes the other way around as well.My point is that there seems an implication that there can be major, difficult if not impossible to correct, imbalances in frequency response in that part of the spectrum so the image presented is inevitably skewed by that. If the q is assessing the degree to which stereo bass is perceptible, surely you have to correct for this, just as you correct for volume differences in other such tests, otherwise you are not just testing stereo Vs mono.
Put another way, how do you even test if what you hear is from stereo Vs mono if you can't normalise the level/response?
The correction for summed lows is based on the assumption (not any more after all this analysis though) that recordings are indeed mono in amplitude and phase, which are not.
Other signals than the traditional sweeps may reveal another another set of imbalances, as phase differences (like in music) can work destructive or not when played together.
Professional acousticians use very different signals when fixing a room (and laugh at our amateur endeavors) .
As with any other test the results depend on the signal quality and suitability.
And another.
The fact that some findings that do not correlate with the (established but poorly documented) "principles" get so much push back should be alarming in a science based forum. People should jump on testing, not theorizing or defending their time and investment when turns out not ideal.
Just like the FSAF measurement for example, which reveals concerning results at smaller gear so people avoid it like plague.
We should be glad we have the chance to search for ways for the "holy" "as the artist indented" even to a smaller degree and without all the pains and cost of a room with 200 liters flush-mount monitors.
