- Joined
- Dec 30, 2024
- Messages
- 115
- Likes
- 150
the bash 500s is a class d amplifierLOL not really.
Amir describes it as a bridged AB amp in this review, you have something to contradict that?the bash 500s is a class d amplifier
From what I believe is the manual:the bash 500s is a class d amplifier
BASHÆ amplifier technology marries a robust Class AB amplifier with a smart power
supply that adaptively provides the necessary output voltage required to produce
low-distortion output power.
Sadly when I tried to measure max and peak power, the amp shut down and no longer operates.
There's no such thing as a class D power supply. Power supplies are either linear or switching. What they are talking about is a class AB amplifier paired with a switching power supply. The D in class D does not stand for digital, this is a common misconception."The BASH 500S module provides a sophisticated blend of digital efficiency and analog-like musicality, ensuring that your listening experience remains transparent, articulate, and entirely uncolored.
Technical Specifications:
Dimensions: Approximately 29" (H) x 17.5" (W) x 15.5" (D).
Power Output: 500 Watts RMS (Continuous).
switching power supply.This is a bridged class AB amplifier fed by a switching amplifier.
It’s an equivalent statement IMHO.LOL not really.
They could mean a Class AB configuration with voltage switching among multiple supply rails—which is a Class G amplifier—or with a modulated tracking supply rail—which is a Class H amplifier. Both are analog amplifier technologies.Amplifier Topology: BASH (Bridged Amplifier Switching Hybrid) – combines the efficiency of Class D with the high-fidelity sound quality of Class AB."
I was thinking this too. The Crown should have good reputations, and I think I remember seeing a test somewhere.Just get a Crown PA amp or similar. Much easier than building a plate amp into a box and they are powerful, clean, and bullet proof and have extensive DSP and protection capabilities.
www.audiosciencereview.com
Very interesting.Looking at their patent application, we have this high level diagram:
It is an integrated class D power amplifier and bridge linear amp. Unlike a regulated class D power supply the audio signal modulates the pulse width and with it, the output voltage of the class D power supply. I assume this means the power supply voltage tracks the signal, providing high efficiency.
The amplification section is H-Bridge configuration but run linearly, not switching. Hence the "AB" nomenclature. Here is a more detailed schematic of that:
I fixed it.
