Bang & Olufsen Beosound Balance Review
Rate this smart speaker:
    Votes: 72 35.8%
    Votes: 91 45.3%
    Votes: 31 15.4%
    Votes: 7 3.5%
saw the page just loaded for a moment I thought that since Amirm often talks about cooking, it was the test of a new blender ... ;) I fear I will have to start using glasses ...
jokes aside, the type of clientele and use of these speakers, will hardly be reconciled with acoustics and equalization problems.
These devices are taken, placed on the beautiful furniture in the living room of the house and used for pleasant background music at dinners with friends, controlled by the smartphone. I have heard some, of different brands, and it is surprising in any case the way they sound considering that they are "single channel".
Thanks Amir for the review
That only makes the performance of the Beosound Balance (balance of what???) even more inexcusable.
Is there a B&O dealer where you live (there was when I worked in the town, but it closed a good while back I think)? I suppose the only way to check the overall balance is a kind of 'in room' measurement which, in any case, I think Klippel does or works out?
P.S. When i worked for a 'Home Counties' B&O dealer long gone now, some of the speakers we installed were hidden behind curtains (the wall hanging 4500 range ewas one, the slim column Beolab 6000 was another I recall)
There was a version with amp built in, the display obviously hidden in such a position...
Funny thing was, they didn't sound as muffled as you'd think, when sited this way :D
It's time we get a Dirac AI "solve all room issues at once" implementation. :cool:
I cannot imagine such a thing won't be there withing the next 3-5 years.
The value equation is very difficult to defend when there are ample similar products for a fraction of this cost.
Can you think of another omnidirectional speaker that sells for a fraction of the cost that goes down to 30Hz and has the same build quality? If you can name one, I will change my vote from "Great" to "Poor".
One thing that strikes me about the contour plot is the lack of left/right symmetry. It made me wonder how the drivers are arranged in this thing because Amir mentioned he had difficulty finding where the tweeters were. I was wondering whether the awful measurements may be due to the microphone not positioned along the tweeter axis. What do you think @amirm?
Yes, there used to be. I can still picture the shop front, although I don't think I ever went in. I don't know when it went (or when Listen Inn went for that matter).
I've often found that speakers sound better in "odd" places than you might expect. Curtains might be no worse than some grilles.
I always thought that B&O stuff looked great and was only slightly overpriced. I might have gone for the 4000 parallel tracker TT if I wasn't into the whole "Linn thing" by then.
The DUT makes no sense to me by any measure.
This is a review, listening tests, equalization and detailed measurements of the Bang & Olufsen Beosound Balance wireless speaker. It was kindly drop shipped by a member and costs US $3,299.
The Balance doesn't deviate much from the typical look of these speakers but does manage to feel/look luxurious. Importantly, it is substantially heavier than any other smart speaker I have tested, bringing hopes of higher playback volumes and bass response. I was pleased to find good connectivity including analog input which I used for measurements (does away with latency of wireless connection):
I do wish the ports were labeled however. The info is in the manual but that is also hard to read with every paragraph written in what seemed like a dozen different languages.
The design is complex as you can see from this picture:
There is a woofer on the bottom followed by midrange in the middle and array of tweeters.
Typical of the class, you need to use an App to setup and configure the speaker. Like most of its competition, the app was a bit glitching, ending the setup with an error. But when I restarted the app, all was well and speaker was ready to be used. Navigation through the app was non-intuitive. For example, when try to play Tidal, it got me to login but then complained that the content can only play through the Tidal App???
Upon configuration, speaker has a forced room optimization where it played a single CHIRP tone and proceeded to activate that mode. Playing music at that point sounded decidedly "wrong" so after much searching, I found the option to turn that off. Turning it back on forces the calibration all over again, making it hard to do AB testing of what the difference is.
There are four or so playback scenarios from voice to "optimal." It defaults to Optimal which I again found to not sound good. For simplicity of measurements (and better sound as you will see later), I configured the Balance in "Front" mode. As the name indicates, this setting sounds more like a normal speaker with sound firing toward you.
Measuring such a complex design and interpreting the results is not straightforward. As such, I highly recommend that you don't skim through the review quick and do pay attention to the listening test section.
If you are not familiar with the measurements that are about to follow, I recommend watching my video on understanding speaker measurements:
Bang & Olufsen Beosound Balance Speaker Measurements
It was challenging to find the tweeter as you cannot feel its location through the fabric. Nor is there a clear "front" reference. I guess at both, resulting in the following anechoic measurements:
Due to complexity of the soundfield at higher frequencies with multiple tweeters overlapping each other, the off-axis response past 8 kHz or so drops in accuracy. On-axis response though, was hardly impacted. At first glance, this seems like a mess: we have pronounced resonances around 1500 and 3300 Hz and droop around 220 Hz. Note however that bass response goes quite deep which is very unusual for such a small speaker. The sound power hugs the on-axis response indicating that we have an omni speaker despite me selecting "front" mode. Given this early window and predicted in-room responses mirror on-axis response:
It is harder to see the omni behavior through directivity plots but it is there if you look at the scale:
See how the response goes to -180 degree or so up about 1.5 kHz. The contour graph shows this more clearly:
While there are potholes, the response is generally even in amplitude across the full ±180 degree spans.
Vertical response is decently broad but obviously not omni:
I stopped sweeping the speaker at 86 dBSPL and instead, added 80 dB for refence in our distortion tests:
Subjectively the response was much cleaner than what the above shows, perhaps due to ultra low distortion between 1 and 4 KHz where our hearing is most sensitive.
The waterfall display is super busy due to multiple resonances:
Step response also shows high level of complexity due to multiple drivers firing:
Bang & Olufsen Beosound Balance Listening Tests and Equalization
Based on my setup experience and measurements I expected horrible sound when I fired the speaker in my near-field setup. To my surprise, the opposite was true: the deep bass was quite satisfying overall fidelity seemed pretty good! Surprised, I changed the setup from Front to Optimal and fidelity sank big time. I then ran the Room EQ and that made things even worse! On this topic, I don't see how EQ works when the measurement is at speaker rather than listening position.
I turned off Roon EQ and set the speaker back to front. Then started to develop a few crude filters to back out major issues in on-axis response:
Sorry, forgot to drop down and show the actual filter settings (can't do it now without repowering the speaker). Will show them later. For now, it should be rather clear what the filters do. The collective set markedly improved fidelity. Female vocals were now more balanced and not so forward as with the stock tuning. That deep and clean sounding bass was there to provide major satisfaction.
Spatial effects were a major surprise. On some tracks with high frequency instrumentation, there was a gorgeous halo of sound in a hemisphere behind the speaker. Closing my eyes, I enjoyed that image maybe even more than a set of speakers in stereo configuration! There seems to be something to this omni response and back firing mid to high frequencies.
Sub-bass response was poor with clear distortion but go up a few hertz and per my earlier notes, the bass was absolutely clean. FYI most of my listening was with the volume at 50% with listening distance of about 2 meters/6 feet. Based on this, I think you will be able to fill even a large room with the Balance speaker.
Once there, I did not want to stop to take a picture of the speaker in my photo booth! The overall fidelity and experience was that good with equalization.
Coming into this review, I was not hopeful that I could quantify the performance of B&O Balance. But when I completed the full circle of analysis including listening tests and EQ, the story came together. First, the modes and room EQ in my opinion do a lot of damage. I don't know what listening tests were performed but in my book, they just sound wrong. Yes, I could have made before and after measurements but this is a complex speaker and single microphone measurements are going to be hard to interpret. Fortunately these modes can be turned off. Then with some EQ -- which would have been nice to have in the speaker itself as it clearly has that ability -- produced excellent sound. Despite the complexity of the speaker, measurements did provide great insight as to what needed fixing. Again, shame that this was not done in the speaker to begin with.
The old saying of diamond in a rough describes the speaker. If you can EQ it, I can recommend the Beosound Balance. We can fix the flaws with EQ but can't bring bass response and dynamics to the table which is the major failing of this class of speakers.
Obviously there must be two typos:
1. isn‘t the price of this gem $ 329,—????
2. you wrote: „I turned off Roon EQ“ instead of „room EQ“
<https://www.audiosciencereview.com/forum/index.php?threads/apple-homepod-review-smart-speaker.23882/>
That's a *lot* of money.
Fine if you want to spend, and can justify it.
Not on any kind of radar otherwise.
Lifestyle products, just not mine.
Interesting review though, looked like it was tricky to measure. Enjoying the variety here.
Not an Apples to Apples comparison and the B&O has significant Onboard EQ. But I own two of these and for bedroom duty they are not bad. $200 each.
B&O is doing what B&O have always done. Design as main priority and hoping their wealthy customers with modern clean homes feel like it's time for a new gadget.
They can and do make some quality built and great sounding products. They have some very knowledgeable people on board. It's just that the design and marketing in this particular project seems to have had more to say than the sound engineers.
Like the famous Egg Chair by Arne Jacobsen I have seen at some fancy Scandinavian hotels, this speaker would fit the decor of that.
As a teenager in the 80s, my musical coming of age occurred through my dad's Beocenter system and Beovox speakers. We had some great family evenings listening to some new LP dad had bought (not much TV back then, so music was the thing).
Great design, way ahead of its time. The sound was glorious too. But B&O products they have always been way overpriced for what they offered.
If one wanted to make a statement, it was an object of desire. But the same audio performance, if not better, can be had for much much less.
GSP
All those problems and high cost and it still gets a recommendation?
It is not my place to judge what is high cost to membership. Unless a product is specifically designed to be very low cost, that factor tends to not be included in my judgement. Except, if it is awful and expensive. In this case, with EQ, it is a very enjoyable product so gets my recommendation.
Thanks. In that case I changed my vote from "Great" to "Poor".
Wow, more than 3K for a bunch of drivers that cost peanuts! This is a huge amount of added value. Great!
One must understand that @amirm has "just" delivered very valuable measurements [thank you very much for this] and whatever his personal opinion is, ignore the latter if you don't agree and please refrain from questioning his subjective conclusion.
