Balanced to unbalanced cables for subwoofer?
olds1959special
Los Angeles, CA
To avoid using splitters, I used balanced to unbalanced cables out of my DAC to connect my subwoofers. Is this okay? Will sound quality suffer?
There's a big difference between measurable and audible. And if it's not audible it hasn't impacted the sound quality.
Actually it did sound worse.
How does a single balanced connection become two single ended connections without splitters?
SQ is only one of the worries.
The other one is the device going doorstop.
S+ and GND to one sub
S- and GND to second sub and then invert the signal at the sub. Failure to invert the signal will kill overall sound quality
