Hador
Here is my setup:
I use the balanced TRS output of the DAC, a Topping D50 III, and go into the external EQ (Nubert ATM 381). The EQ only has normal (not balanced) RCA inputs/outputs. From here I move on to the balanced input of the amplifier, a Topping PA5 II.
Now my questions:
1) Is it expected that the EQ will have problems with the balanced signal?
2) Does the balanced signal path even make sense if a component in between processes the signal not balanced? Would it make a difference to also use the RCA connections on the DAC and amplifier?
Thank you very much for your help in advance!
Now my questions:
