Does anyone have any experience with Sommer Cable Peacock Twin (Shotgun) Balanced Cable? I want to use it to make balanced splitter cables to connect my Topping EX5 to my iLoud MTMs and Presonus Sub8. And it looks ideal for my little project...
I currently have XLR to TRS cables going from my Topping EX5 on my desk, down through a cable snake to my Sub8 on the floor. I then have another set of TRS to TRS cables going from the Sub8 output back up through the cable snake up to the MTMs mounted on my standing desk.
Building a splitter cable would:
Thomann sell it a bit cheaper per metre, but they want £10 delivery, so it works out more for this small amount...
www.thomann.co.uk
- Reduce the number of cables run through the cable snake (it's a bit busy in there).
- Avoid sending the signal for my monitors through the Sub8 (which might be a bit noisy https://www.audiosciencereview.com/...ough-and-hpf-measurements.60664/#post-2221902).
- Give me a bit more play in my cables (the ones I use now are only just long enough).
Sommer Peacock Twin Balanced Splitter Cable. DMX Lighting Mic, XLR, TRS 200-055* | eBay
DMX Lighting Mic, XLR, TRS 200-055 . This includes Channel Islands, Northern Ireland, Isle of Wight and Scottish Highlands. - Jacket material (AES/EBU, DMX): S-PVC. - Number of Channels (AES/EBU, DMX): 2.
www.ebay.co.uk
Sommer Cable Peacock AES/EBU Black
Microphone Cable Balanced twin cable, DMX, 2x 2x 0.22 mm², 110 Ohm, Hardwearing, Colour: Black, Dimension PVC 4,0 x 8,0 mm
