- Thread Starter
- #21
So you don't think the mogami 2534 is proper coaxial cableYou can, but it's generally a bad idea. Unbalanced RCA connections should be done using a proper coaxial cable.
Do you think the mogami 2534 has this proper sheilding, do you think it is suitable for this applicationPlease understand that the "balanced" noise rejection is performed by the input device that subtracts the hot from the cold, which thus cancels out (rejects) any common noise that was introduced in the cable transmission.
An unbalanced input device does not have that mechanism since it is only taking input in from a single conductor. As a result, whatever you do in the cable won't matter.
Proper shielding is an independent matter. Coax cables are already designed to provide the proper shielding for unbalanced analog signal transmission over long runs (and short runs).
Mogami 2534 is a quad conductor plus shield cable typically used for XLR (balanced) connections. It is overkill for single-ended RCA cables, not needful for that application. For XLR to XLR in a high-noise environment it works great, and alot of folk use it at home even though I tend to think it is overkill there as well. It won't hurt anything but your wallet.So do you think the mogami 2534 has this proper sheilding, do you think it is suitable for this application
Thanks. I've already purchased it though, that's the thing.Mogami 2534 is a quad conductor plus shield cable typically used for XLR (balanced) connections. It is overkill for single-ended RCA cables, not needful for that application. For XLR to XLR in a high-noise environment it works great, and alot of folk use it at home even though I tend to think it is overkill there as well. It won't hurt anything but your wallet.
Could you provide a link to what you purchased, since the connectors and the wiring matter as much. And remind us of what devices you are connecting with that cable.Thanks. I've already purchased it though, that's the thing.
Would save me having to spend more money on buying more cable, or do you think i would be better off with a different cable
It is not a coaxial cable.So you don't think the mogami 2534 is proper coaxial cable
It's not coaxial but it will be perfectly ok.Do you think the mogami 2534 has this proper sheilding, do you think it is suitable for this application
It's fine.Thanks. I've already purchased it though, that's the thing.
Haha, of course they do. You clearly haven’t tried different cables.Not sure what you mean here, the cable either works or doesn't. If you mean, how does it sound... cables generally don't have a sound.
JSmith
I suspect most of you on this forum have never heard a world class system, which is sad.
Maybe sharing how much of a difference placebo makes too. What do you think the cable is doing that Mogami cable is failing to do?Haha, of course they do. You clearly haven’t tried different cables.
In response to the post above, “is there anything better”, of course there is - but you’ll pay more.
While waiting for a better cable, I bought a 10m Mogami 2549 quad XLR. It does the job, and for $200 it’s more than fine. But it sounds sterile, and not at all as great as the previous cable (which was too short).
Does the Mogami suck? No, for the money, it’s great. I’m sure it measures well, etc. But if you have a great system, it won’t do anything positive to it.
Just thought I’d share as I was just reminded how big of a difference cables make.
Stop trolling.I suspect most of you on this forum have never heard a world class system, which is sad.
No, you just thought you'd sit there at your keyboard rubbing your hands together in glee as you shitpost at ASR.Just thought I’d share
LOL thanks for the laugh. Which nonsense cable outfit did you buy into particularly? Please educate us on world class systems, too...Haha, of course they do. You clearly haven’t tried different cables.
The physics involved with audio cables, voltage dividers, capacitive and inductive reactance determine that audio cables do not have a sound providing they can conduct the signal without becoming resistive. You are deluded and it is almost guaranteed that you have never done an ABX test to prove that cables do not sound different.Haha, of course they do. You clearly haven’t tried different cables.
P.R.a.T.Haha, of course they do. You clearly haven’t tried different cables.
I just wish to add there are apparently two different kinds of Mogami 2964: one with and one without the "W" in the cable part number.For Unbalanced: Mogami W2964 or W2965
I'm not sure that is the case; and I suspect that it is just a nomenclature difference of when the "W" is used before the wire part number.I just wish to add there are apparently two different kinds of Mogami 2964: one with and one without the "W" in the cable part number.
