babadono
- Joined
- Jul 8, 2021
- Messages
- 563
- Likes
- 402
ummmm...ok...I can try to explain. There are different types of balanced outputs. One type has a signal on the + output only and the - is just an equal impedance to ground. On this type it is ok to use the + signal and tie the - to the ground of the input of unbalanced inputs. The CMR of the connection will be lost (or very limited) but no harm will be done to the circuitry.The other type has signals on both the + and - outputs. Being there is a driven signal on the - it should not be tied to the unbalanced input circuit ground i.e. left floating. There are "fancy" derivations of this actively driven type of output, a transformer or cross coupled output that would allow the grounding of the - signal without damage. But these are rare. Best to use the safe connection if uncertain. Or use the recommended hook up specified by the manufacturer.
