genius8086
- Joined
- Nov 17, 2025
- Messages
- 4
- Likes
- 0
Hi everyone, I’m struggling to get the audio from the 4.4 mm balanced output of the FIIO KA15 to sound right on my Presonus Eris E4.5 monitors.
1) Buzzing noise on PC. The biggest issue (which does not occur when using an Android smartphone) is a buzzing noise during playback. It happens at specific points in the audio and always in the same places. I suspect it’s related to the overall output level, which becomes distorted when the KA15’s output gain is set higher than ~44 (out of 60). While this might not seem like a big deal, the whole point of using the balanced output was to achieve a louder signal without increasing the volume on the Eris E4.5 speakers (which adds a bit of white noise when turned up). With the unbalanced 3.5 mm output, I can set the KA15 to maximum volume and get a louder, cleaner signal, making the balanced output pointless in this case.
2) Poor channel separation. When using the 4.4 mm balanced output, stereo channel separation is incorrect. I can always hear (quiet, but still audible) a trace of the opposite channel when I carefully listen to the left or the right speaker. I connected headphones to Eris E4.5 and used the proper content, there is no doubt that the audio is separated wrong. This becomes more noticeable as the KA15’s output gain exceeds ~44 (marked as 44A on the device's LCD screen), so I believe this issue is related to the first one. The difference is that on PC, with a high enough output level, you hear the buzzing noise, whereas on Android this noise does not occur.
Wiring details: the balanced output of the FIIO KA15 appears to follow this pinout (starting from the tip of the 4.4 mm jack): L+, L–, R+, R–, ground. The Eris E4.5 has “plus,” “minus,” and “ground” (starting from the tip) for each balanced TRS input, with left and right channels separated. I’m using the following cable: 4.4 mm to 2 × 3.5 mm balanced (https://www.amazon.de/dp/B0FBF7HBVQ?ref=ppx_yo2ov_dt_b_fed_asin_title). I ordered several of this type and checked the contacts with a multimeter, they are compatible and mostly identical. Then I use 3.5 mm to 6.25 mm adapters to connect to the speakers.
For the easy listening test I used the bass sound after the intro in Queen’s song "Breakthrough" (0:35), and both issues are clearly reproducible. You can definitely hear a trace of the opposite channel, which should not be there, and a buzzing noise. Playback was tested with foobar2000 v2.24.5 on Windows 10 (KA15 in ASIO mode), the issue occurs regardless of format (MP3, Audio CD, FLAC, DSD). It’s not even about the media player, the channel separation issue happens with Spotify player on Android.
If I connect only the left or right TRS cable separately, none of these issues occur. There is no distortion even at maximum KA15 output level, and obviously no channel bleed when only one channel is connected. My guess is that the shared ground may be causing the problem, or perhaps these cables are designed for headphones and not intended for use with studio monitors (even entry-level ones).
Some setup details:
FIIO KA15 firmware v1.1.2 (latest)
ASIO driver 5.74.3
NON-OS filter, EQ off, DAC class H, DRE disabled
Eris E4.5 works perfectly with unbalanced connections
Thank you in advance for your help, I’m hoping for some professional advice from this forum.
Some setup details:
ASIO driver 5.74.3
