There's no simple answer. For long runs between rooms it might help (if you have ground loop hum or other noise issues). Between buildings or across a football field, I'd say it's a really-good idea.from what length on?
As all the others have said, it depends upon the application and environment. A ground loop can cause hum with a 1" cable if the problem is not the signal path. A single-ended cable 100' long may be fine if there are no noise sources that couple to the cable.Does it make sense to go balanced with cables on shorter lengths or if not, from what length on?
Higher output power, or lower? Higher output usually implies more gain through the amplifier, but higher signal level and lower amplifier output impedance is usually less sensitive to noise -- except ground loops, which can sneak in at the input.It doesn't matter a lot for headphones cables, but when it does it's for higher output power. Unbalanced cables are in theory more susceptible to EMI/RF, but in practice it's not picked up audibly through headphone cables.
No, balanced can't hurt the sound quality.Thanks all. Am I correct in assuming that the signal is passing through extra circuitry and amplification when going through balanced? Couldn't that itself be detrimental to sound (S/N)?
If poorly designed, yes, but the same goes for single-ended electronics. The trick with balanced is that it's supposed to increase SNR, because:Couldn't that itself be detrimental to sound (S/N)?
COMPONENT | #1 (all RCA) | #2 (XLR TT to Phono) | #3 (XLR Pre-Amp to Speakers) | #4 (all XLR) |
Turntable | Pro-Ject Debut Pro S | Pro-Ject X1 B | Pro-Ject Debut Pro S | Pro-Ject X1 B |
Phono Stage | Pro-Ject Phono Box S3 B | Pro-Ject Phono Box S3 B | ||
Streamer | WiiM Pro Plus | WiiM Pro Plus | ||
Amp/Pre-Amp | WiiM Ultra | WiiM Ultra | Topping A70 Pro | Topping A70 Pro |
Speakers | Kali Audio IN-5 | Kali Audio IN-5 | Kali Audio IN-5 | Kali Audio IN-5 |
$$$ | ~2,000EUR | ~2,440EUR | ~2,333EUR | ~2,800EUR |
