How loud does 8Hz need to be before you can actually hear it and can real subs get you there?
Watanabe & Møller 1990. This is the measured threshold of hearing curve down to 4Hz (Watanabe & Møller 1990), showing SPL needed just to detect a tone at each frequency.
for 8Hz:
~100 dB SPL = threshold, barely detectable, this is the graph's curve.
~103-105 dB SPL = clearly audible tone. Loudness compression at low frequencies means it doesn't take much: Yeowart et al. (1967) found that near 4 Hz, about 1 dB was enough to go from inaudible to clearly detectable.
~120-125 dB SPL = 'vibrotactile sensation' begins (felt, not just heard), per Møller & Pedersen, that's roughly 20-25 dB above threshold.
I sit and did the math with Claude, here's the table of how many subwoofers needed in a sealed room to reach audible levels of 8Hz.
| Config | Sd total | Excursion (peak) | Room volume | SPL |
| 2×18", Sd≈0.12 m² each | 0.24 m² | 15 mm | 50 m³ | ~111 dB |
| 3×18" | 0.36 m² | 15 mm | 50 m³ | ~115 dB |
| 3×18", long-throw | 0.36 m² | 25 mm | 50 m³ | ~119 dB |
| 3×18", long-throw | 0.36 m² | 25 mm | 30 m³ | ~124 dB |
The critical detail is that the room has to be sealed. Once it is, pressure chamber conditions take over: SPL is determined by cone displacementrather than the acceleration of the moving air. So, only 3 capable 18'' drivers are 'enough' to make 8Hz audible.
