Recently I have aquired an Audiotechnica AT33xMONO/I to rip my mono records.
Pretty much everywhere I looked people reccomended a true mono cartdridge over using a stereo cart with a mono switch. I read phrases like "A mono switch will (only) get you 80% there"
However, while ripping a mono record from 1964 (so its pretty much guaranteed to have been cut using a stereo cutter head) I noticed some pretty horrid inner groove distortion on the last track each side.
I thought "Oh well, guess the record was just badly cut that way". But out of curiosity I re-installed my trusty stereo cart today (Shure V15 IV with Jico SAS/B stylus) and ripped the same problematic track using a mono switch. The distortion is VASTLY lower on the stereo cart.
I suspect the stereo cart has the advantage of having a micro-line (SAS) tip, but mono carts only seem to come with conical styli for the most part + I read they don't have issues with IGD.
What gives? Have I really just wasted 600€ on a cart that sounds inferior despite the common conception that a mono cart beats a stereo cart + switch???
Here's both carts to compare. They system was tuned for a flat frequency response using the Clearaudio TR-1007 test record & sjplot with each cart setup individually.
The Audiotechnica seems to ALSO lose trebble response towards the end of each side and sound "wooly", while it sounds pretty much identical to the shure at the start of the record.
Shure V15 IV with Jico Sas/B stylus, summed to mono. VTA setting at +1, Tracking Force 1.75g, antiskate at 1.75:
drive.google.com
Audiotechnica AT33xMONO/I . VTA setting at 0, tracking force 2.5g (with the technics auxilery weight added to the tonearm.), antiskate at 2.5::
drive.google.com
both have been aligned using the same protractor.
Overall system:
Technics SL-1210 GR2
Musical Fidelity V90-LPS Pre-Amp
EVGA NuAudio Soundcard used for capture at 192khz, 32bit.
is there something i'm doing wrong? Right now I feel kinda pissed at the AT's performance and think of selling it again...
99.9% of the mono records I own are from 1960 or newer.
Shure_V15_IV-JicoSASb.wav
Audiotechnica_AT33xMONO-I.wav
Overall system:
