BACCH4MAC Short Review / first impressions
sweetsounds
So I finally broke the bank and purchased the Intro version of BACCH-DSP 4 MAC (V12.2).
Introduction
My experience is, that the interaction between room and speakers has by far the greatest impact on how I enjoy music listening. Most of my upgrades of the last 10 years went into room acoustics (without completely sacrificing the looks of the room). I also finally got good results using Acourate as a digital room correction solution to compensate for the rest.
My personal findings so far match the research of Toole/Olive, namely that a flat frequency response on axis (and an even behaviour also off-axis) makes music sound "right" and for imaging you want to either absorb first reflections or diffuse, but definitely you want to diffuse late room reflections to give a sense of space. So put diffusors at the backwall and also between the speakers. A decay time RT60 of 0.25 to 0.3 seconds works very well. Below the transition frequency use bass traps and DRC. Wide dispersion speakers yield a good compromise between tonality and sound-stage. Directional and bipolar speakers like Magnepans are difficult to set up.
What BACCH-DSP does
BACCH seems to be around since 2015, developed by Prof. Edgar Choueiri of Princeton Univ. His company Theoretica Applied Physics is now more present at HiFi shows demonstrating the effect. It is a DSP that eliminates speaker cross-talk (XTC) at the listening position by a sort of a cancellation pattern (similar to noise cancellation) while avoiding frequency artifacts due to the interference. To quote from his paper: "These two series of pulses are delayed by τc with respect to each other so that after the first positive pressure pulse arrives at the left ear, then reaches the right ear with a slightly smaller amplitude, it is cancelled there by a negative pressure pulse of equal amplitude (that was emitted a time τc earlier by the right loudspeaker), which in turn is cancelled at the left ear by a positive pressure pulse, and so on. The net result is that only the first pulse is heard and only at the left ear, i.e., with no crosstalk"
It is not a new concept, but BACCH implements it very smartly. It has special algorithms for bass and mono signal treatment and lots of calculation to minimize colorations.
BACCH DSP is available in three flavors, all based on a similar/same set of algorithms
1. Expensive: BACCH4MAC intro, at $1000. You can't customize the XTC elimination filters, but can use only a generic model based on the distance between you and your speakers (uBACCH)
2. Very Expensive: BACCH4MAC audiophile $5000/$6000 with a binaural microphone + interface to measure your system's response. It also offers head tracking by webcam to maintain the benefit when you move.
3. Ultra-Expensive: BACCH Sound Processors stand-alone equipment from $20k to $50k, which you can easily plug into your signal path.
Options 1 and 2 require an Apple Mac in the signal path to run the DSP software. This adds another $1000 and honestly reduces the usability of my system: I have not yet succeeded in making the Mac headless, so I need a monitor and mouse to configure it.
You can try option 1 for 2 weeks with full refund.
Setting it up
My current setup consists of a central music server running Logitech Media Server 8.4, a raspberry Pi endpoint running SqueezeLite on AroioOS and BruteFIR DRC. This is feeding a SMSL VMV1 DAC via coax and Classé M600 monos into Magico S5 Mk2. I always wanted to avoid the hassle and - maybe irrationally - the electrical noise of a PC in the sound-chain.
It is an easy-to-use configuration. Just switch it on and select the music with the iPeng app.
When you buy the BACCH software, a service employee (in my case it was Edgar) helps you perfectly by phone to get your system running. Support of Theoretica is unbelievable! Edgar spent more than an hour with me explaining everything.
Here is what we did: set up the Apple Mac Mini M1 16GB running SqueezePlay (you can also use Roon, HQPlayer or probably almost any other software which plays music).
You need BlackHole Loop Back software to re-route the sound on the Mac from SqueezePlay to BACCH-DSP (simply create an aggregate device in the Audio/MIDI Settings with BlackHole + your DAC as sources, set the clock source to your DAC and tickmark drift compensation for BlackHole). Call this aggregate sound device "SF4BACCH". Then in the BACCH-DSP software select SFBACCH in the Auto-Configure drop-down menu. Now select a filter bin, click "ARM". enter the distances between you and your speakers and between the speakers, and click FIRE. his is more or less it, but there are some pit-falls where Edgar helped.
Another challenge was to include my DRC filters. They need to go after the XTC filtering. BACCH-DSP supports VST/AU/VST3 plugins, so you can use a Convolver VST plugin.
Selection on the Mac is huge, but some free ones don't work. Edgar recommended Reverberate (which will cost you another $99). It is not as great as BruteFir or Accourate Convolver as it doesn't change sample rate automatically for instance.
So my signal chain now looks like this:
Server (running LMS) ==> (ethernet) ==> MacMini (running SqueezePlay, BlackHole, BACCH-DSP 12.2, Reverberate Core VST3 for the DRC FIR filters) ==> (USB) ==> DAC
More complex setups with active XOs should be possible and VST plugins like Elements open further realms for post-processing.
What is the effect
Hard to describe, it creates the impression of a 3-dimensional room in front of you, musicians and sounds eminate from a precise spots in the room rather than from between the speakers, sometimes even far outside the physical dimensions of your room, or from the side/behind you or from the top.
The effect is most evident when I switch to Bypass: the musicians are pulled with a rubberband from their positions around the speakers back to a position in the speakers' plane. The 3-dimensional room collapses.
When switching it back on, the musicians slowly move to new positions in the room, sometimes almost next to you. It takes a couple of seconds for your brain to accomodate and grasp the virtual room around you. On binaural recordings of Chesky you can have people walking up close to you and whispering. It's more than a gimmick, you forget rapidly that it's there.
The magnitude varies greatly with the musical pieces. Since cross-talk is elminated your brain is re-interpreting the spatial cues which are in the recording. If there few or none, there is also no effect and no change in the presentation.
In any case, the speakers vanish. I guess this comes from the fact, that each ear gets fed with signals coming from the respective side only. So your brain has no cues from the other ear for the speaker's position.
Which music is benefitting
Naturally, the effect is biggest with binaural recordings, but many standard recordings work as well. Best is live music like a classical orchestra, electronic music sometimes is excellent, straight studio recorded pop-rock is not benefitting much in many cases. There is a thread with a list of recordings on this site, start looking there.
Limitations of BACCH
- The system complexity is higher, you need a Mac (and I don't like Macs)
- Usability of the software is astonishingly good, but the fonts are so small, that using it in a listening environment is tedious.
- The magnitude of the spatial improvement varies a lot with the music. If studio recordings with individual mics are your thing, the benefit might be less.
- For best results your speakers should be directional (electrostats, horns, bipoles), not like my Magicos. Or/and your need absorption. Or/and you should sit in the near-field.
This goes against my old concept in some areas, where I sought a wide off-axis response of my speakers and diffusors to create more equal room response for adding volume to the sound. I also have super-tweeters firing up / to the side to increase spaciousness. With BACCH these are counter-productive.
- BACCH interacts with the DRC filters, making them less effective. Edgar's recommendation is, that you need to extract the DRC filters with BACCH activated.
- Despite the claims to the contrary, I hear some minor changes in the frequency response/colorations with BACCH. Bass is almost unaffected, but the mids are a little recessed and the highs are more pronounced. It is not much, but clearly audible.
- the sweet spot becomes very small. The cancellation is optimized for your position. This is a limitation of the uBACCH fixed filter version. The higher versions use a webcam to track your head.
- BACCH-Intro is limited vs the full version, because the filter is not optimized for your room (can someone share experiences of using uBACCH vs full filters?)
Overall
DSP is the next level of HiFi.
DACs have become perfect, amps are ultralinear, music streamers provide endless libraries without noise. Yet, how to deal with the limitations of speakers (even though Magico, D&D, Kii and others have come a long way in smooth response without distortions and ported designs, the room modifies it)? Even worse, what to do with the issues of our rooms?
Digital room correction with Dirac/Acourate has compensated for frequency errors and timing.
BACCH eliminates another issue - the problem of cross-talk during speaker reproduction, namely that your left ear hears the right speaker (which it should not) and vice versa. It also works for headphones, removing the unpleasant issue of the "soundstage inside your head" by using head-tracking.
Floyd Toole mentioned, that of course correction is always the second best choice. The best choice would be a new sound format, where the room and frequency information is encoded and an optimized decoder regenerates the desired sound-field. While this is a great idea, it won't come anytime soon and won't work for existing recordings.
So XTC and DRC are great bets to improve your listening experience in your setup with your music library.
Save your money, don't buy expensive cables, another shiny amp, a DAC with almost the same specs, or esoteric products like holographs.
Try something new based on mathematical algorithms of sound reconstruction.
Edgar hinted, that there will be a version of BACCH coming our way with XTC and binaural room correction! That would be a killer and fix some of my above issues.
Yet, it will require the Audiophile version and break the bank again.
tuga
Oxford, England
Interestingly I tried an online test of crosstalk cancellation with the iMac speakers and as soon as I increased the intensity of the effect it sounded like the music was coming from the bottom of a well, and I felt an unpleasent phasey sense of "soundstage inside your head".
I can't recall the manufacturer/developper but I am almost sure it wasn't BACCH.
phoenixdogfan
Nashville
Interesting you are getting these results with just the Into version. I do listen to a lot of multi mic recordings, so I'm wondering how much I would benefit from this, but I will be switching to a Mac M1 Mini sometimes early next year, and for another $1000, it seems doable. I won't be using Magicos, more like LS 50 Metas, but I understand they demoed a lot with LS 50s in the early days, so it may be a good match.
phoenixdogfan
Nashville
"You need a Mac" is a complete dealbreaker for me.
Personally, my concern has been whether I can get it to run all my AV server functions. It will run all the streaming services both music and video. Will run my chrome browser. Will run JRiver and Dirac. I can run PEQ in JRiver, so no need of EAPO, but crossovers for the subs were a problem as Macs seem to lack a suitable digital crossover. However, Dirac is scheduled to release DLBC in January, so it will do that function. With that, a Mac will do everything I need a home theater server to do, and probably do it faster, with better memory, graphics and speed. For me, it should be a dramatic upgrade over the Dell I3 I have been using. Dead quiet as well, and not really that expensive.
Keith_W
Melbourne, Australia
If you are running JRiver, can't you use that as a digital crossover?
After reading this thread, I had a good look at BACCH and saw that its built-in convolution engine only supports a 6 channel crossover. I need 8 channels. Documentation on how to implement BACCH on their website is seriously lacking. Do you know of any other online resources?
hege
Finland
You could always try installing MacOS on your existing PC, Hackintosh anyone? I'm just pondering whether to do just that, as my Lynx E22 should work there too. As a previous Smyth Realiser owner I know these kinds of DSP gadgets can achieve excellent results, could be a fun experiment to test u-BACCH for few weeks.. my room is super damped so I guess it should work good.
kthulhutu
Glad you are enjoying it!
Can you elaborate on what you mean by "BACCH interacts with the DRC filters"? From my understanding, this may be true of u-bacch filters that assume perfectly symmetric speakers, but with custom filters you can apply any DRC or DSP in the chain before BACCH and measure the filters with them.
Your report of frequency colouration in the mids and highs sounds like an HRTF mismatch with the dummy head used. I have proven that custom filters do not affect FR even slightly when L+R channels are measured (when channels are measured individually you may observe a dip in the bass depending on the XTC bypass freq)
sweetsounds
sweetsounds
I think, this is doable by using a VST plugin.
First of all, if you use Element Modular Plug-in Chainer https://kushview.net/element/ you are free to create your signal processing chain after BACCH has done its processing.
A great post can be found here as well https://www.audiosciencereview.com/...ve-xo-2ch-and-eq-dsp-mac-pc-systemwide.23595/
phoenixdogfan
Nashville
J River is not really versatile. It uses Butterworth filters, but you can build them into the L-R's that I prefer. I just find it easier, to use a dedicated crossover that already does that, and I'm currently using Dephonica with my Windows 10 setup.
My impression is that the Theoretica folks will just walk you through the setup and supply you with a manual once you make the financial committment. And you do have a return period if they can't make it work with your setup, but I'm pretty sure they can.
sweetsounds
sweetsounds
The LS50 will be a good fit, especially if you have some damping. My room is very symmetrical and the absorption seems to help.
The impressive thing is that frequency response only changes slightly with BACCH enabled. On Chesky's binaural recordings there is no coloration at all.
The DRC FIR filters are processed after the XTC processing. Both have an impact on timing behavior of the signal. Consequently, they interfere.
The problem should be gone with a custom measured setup instead of uBACCH.
Keith_W
Thank you so much! I am now seriously thinking about how I am going to get BACCH working on my system. I think it is unavoidable that I have to buy a Mac, and since I know nothing about that platform I will have a lot of questions. I'll do a few searches on ASR and maybe create a separate thread if need be.
Keith_W
I am using LR filters in JRiver. I use Acourate to generate the filters and load them up into JRiver's convolution engine.
On another note, does anyone know how much CPU overhead BACCH imposes on an M1 Mac Mini. The reason I am concerned is because I will be asking a lot of it. It has to run the playback software, do BACCH processing, and process 8 channels of convolution. I have read elsewhere (in the link sweetsounds provided) that using Elements, Hang Loose Convolver, and Roon creates 15% CPU usage. I am skeptical about Apple's cooling solution for the M1 Mac Mini and I am worried that sustained high CPU loads will cause it to overheat and crash. Or if it decides to throttle, that would definitely be audible.
phoenixdogfan
Nashville
All I ever see in YouTube reviews is how fast it can edit a Final Cut Pro 4k video while having 50 or more Chrome windows open. And according to those reviewers, the fan never comes on. So I get the impression there will be no throttling using DSP+Bacch+multichannel 4k video. Better not be.
If anyone else has heard of the Mac 1 Mini taking a shite with this kind of load, inquiring minds would like to know.
Keith_W
Having spent half my day so far reading up about Macs (I know zilch about them) it appears that an M2 Mac Mini is on the imminent horizon. Most people are saying don't buy an M1 Mac now because it is almost 2 years old and due for a refresh.
My other feeling is how annoying it is to configure a Mac. If I want a PC with two ethernet ports, two HDMI ports, and umpteen USB-C ports, and in fact any port that I want ... I can specify the motherboard or plug a card in. No such thing with Macs, you need a dongle.
I have also written to BACCH and to my surprise, they replied. On a Sunday! They think that an M1 Mac Mini has enough grunt to run BACCH, playback software, do 8 channels of convolution, and stream.
phoenixdogfan
Nashville
If the Mac 2 Mini is imminent, that means the Mac 1 Mini will be priced to sell. If it does the job why pay more?
Dialectic
a fortified compound
Usability is reportedly good on the M1 Mac Mini.
I blew money on Mac Studio. Not sure it was worth it.
JRS
Albuquerque, NM USA
Introduction
What BACCH-DSP does
Setting it up
What is the effect
Overall
I've been away from ASR and cannot express my gratitude for the post. I have been aware of this software for some time and based on a couple of short reviews have considered this part of an end game system, preferably one with highly directional electrostatic speakers with huge dynamic range--something like the Sound Lab Model E (the lineup has since been reconfigured to include several speakers intended for sound reinforcement which of course for planar speakers is quite extraordinary--not your dad's Quads to be sure).
One can only wonder what the more expensive implementations using a HTTF are capable of. Unfortunately no outlets on the west coast as of last look about a year ago.
Thanks again for your review. Maybe the KEF R3s I'm considering may be a decent entry level choice, having decent directivity (that some find fault with can now be turned into a huge strength).
Tim Link
Eugene, OR
Thanks for the review! Your impressions sound very much like my impressions from using a divider barrier to eliminate crosstalk. Some electronic music is mind blowing! And indeed, some studio multi mic. recordings have nothing much to benefit. Right now I'm using a 3 speaker array matrixed as L-R, L+R, R-L to do some crosstalk control. This gets me 70% of the way there, with a rock solid center and wide, deep soundstage. It reminds me a lot of the divider wall but much easier to live with. It also continues to sound very nice off axis or in the next room. The center panned sounds stay put but the sound stage collapses, although not completely. It still sounds like stereo. I'd say no worse than going off axis with a standard 2 channel configuration.
