BACCH4MAC Short Review / first impressions
I now have the LP OV2710 cam.. this one: https://www.amazon.com/dp/B00UV89ASO?ref=ppx_yo2ov_dt_b_fed_asin_title
(ELP 1080P USB Camera with Box Housing Autofocus High Speed PC Cameras Wide Angle with 100degree No Distortion Lens Mini UVC USB2.0 Webcam OV2710 High Frame 100fps 60fps USB Web Came for Computer) but it does not switch to IR in a dark room... when I change manually to IR the cam freezes.
Do I need to change some settings?
This is not the IR version, but a normal webcam, at least it doesn't state IR and IR LED illumination in the description.
The IR version typically have a ring of IR LEDs around the lense and a photo-diode.
Once illumination drops below a threshold, there is a click and the IR filter is removed and the LEDs turn on.
I see now. Stupid me.
Should have posted the link
Elp 2Mp Full Hd Usb Camera, Night Vision, 120Fps, Mini Size, Linux Compatible.
You can choose different field of view lenses.
Amazon calls it KLxxIR.
Be careful not to get a fisheye version
Thanks, but for now I let it be.
I've had the Stratos for a few months now. I bought it the day it was available.
I'm getting a slightly more expansive sound than I do with the BACCH/ORC. When I do the sound checks on the program, dog barking, I get the front and side channels, but only one of the rear channels. My speakers are tall, so I'm not getting a lot from the height speakers. Part of the problem may be that II sit on a sofa, so it is hard to turn around and keep my head in the same position for the rear speaker sweeps.
My XTC measurements are a little over 17 dB for both speakers. I was told by their local dealer that because they are so high that there's not much difference between the programs.
Was it worth the $1500? Maybe not, but I would have always wondered about it.
I don’t have atmos installed yet but I suspect that if you have a couch the reflection from it may be interfering somehow. I have a high back sofa and get 20-24db xtc but even small object behind my head can drop it significantly or make one channel have less xtc.
Martin Logan 13a's.
I get about a 12 inch sweetspot, so I don't bother with the headtracking.
My understanding is that once you get past 13-15 dB, you can't hear the difference.
Sanders here myself. 20db + xtc
How wide is your sweetspot without headtracking? The Sanders are much more directional than my speakers. But I can move my head from side to side and stay in the spot. Prior to BFM, I could bearing move my head.
That seems about right with other speakers. If I am getting 14db xtc with the sanders though it means something else is messed up as it’s usually higher.
There is probably about several inches to either side I can move my head in the sweet spot. One a tangent I saw a YouTube interview with Dr Choueiri and he stated with BACCH they have been able to get 2 sweet spots with one pair of speakers. This had been basically considered impossible before.
