You'll hate paying double in the future if you decide that you want it, not to mention between now and then you could've been using/enjoying it. You only live once!I hate returning stuff, though, including software!
I have it setup and running for one week now. My first real use was watching on Apple tv the movie F1. This delivered a very nice experience comparable with an blue ray disks with a regular Dolby 5.1 system. Main advantage of the stratos is for me the better quality sound from hifi set with subwoofer I use. My Dolby surround set has lesser quality gear. Surround music I don't know yet, but that's not really my aim. In future I will connect the blue ray player with the Nuprime 16-AIP with Dante as recommend by Edgar.Have any users gotten up and running on BACCH Stratos?
Did you have head tracking enabled when you did the measurements? I asked about that and was told the measurement sweeps aren't intended for use with head tracking, so it's "not a bug". I don't know if I agree, but there you have itAnyone had success measuring filters under V15?
I just made some 2-step BACCH ORC filters and then proceeded to run measurement sweeps. After I ran the measurement sweeps, the filters I had just created disappeared, replaced by the default filters that come in the software package. Perhaps a new bug.
Thanks all
Well there it is....Did you have head tracking enabled when you did the measurements? I asked about that and was told the measurement sweeps aren't intended for use with head tracking, so it's "not a bug". I don't know if I agree, but there you have it
After one pays the $248 annual tech support/upgrade fee, one gets an email with a link to the newest version.I'm still at 14.2..How does one update to the newest version?
I try to use correct English and always endeavor not to use "you."I haven’t been receiving those emails, despite upgrading to ORC less than a year ago. I will reach out to them to resolve this.
@edit, I guess using "one" was a bit formal/strange![]()
No improvements that I can see other than the presence of the grayed-out Stratos module.How is v15 compared to earlier? I'm on v14 too
One version has the IR tracking. My experience is it’s about the contrast as my camera catches the ceiling lights and blows out the tracking. Dimmer and avoiding direct light in the camera helps. My issues.I boldly installed Tahoe 26.5 and BACCH is still running! However, I’d like some advice regarding head tracking. Currently, I need a lot of light in my room for it to work, but I’d prefer to dim the lights. Which cameras do you recommend?
The ELP OV2710 camera (aliexpress or amazon) works well and automatically switches between ambient and IR light.I boldly installed Tahoe 26.5 and BACCH is still running! However, I’d like some advice regarding head tracking. Currently, I need a lot of light in my room for it to work, but I’d prefer to dim the lights. Which cameras do you recommend?
You should select the right focal length depending if you are on a desk or couch.
A field of view of 50 up to 87 degrees like the KL36 works well for long and short couch distances. Even the 80mm KL80 lens should be enough and avoids disturbing lights.
Regarding latest OS:
Theoretica told me, that there will be an ARM-native version in time in 2027 for the future OS.
It's good if users keep them informed on error or warning messages.
Yes, I use a tripod on a low-boardCan the ELP OV2710 be mounted on a tripod with a screw? I use a flexibele tripod.
