Okay. Do you like them more with eq only in the bass or with eq in all frequencies?I'm already using an equalizer -> RoomPerfect with Lyngdorf TDAI 2170
You can hear the lack of distortion. But without eq the high frequencies are louder compared to a lot of other loudspeakers that is right. The angle of the speaker is also an important factor with no toe in at all or with a very heavy toe in of about 60° (which looks kind of stupid) they should sound less bright.If you equate clean with bright then yes.
Very clean.
I admit they have their own sound, but at that price! If we lived in the same city I would be interested. 803 ebay auHey everyone,
When I just got into hifi, I made the really stupid decision to just buy a set of 802 D3s without doing any prior research and not really understanding what I bought. I coupled them in the living room to my Lyngdorf TDAI 2170 and did love them.
Today, about 8 years later, I am setting myself up for selling them, and it seems the price I'm able to get for them is about 8500$ for the pair.
However, I have tried my old 580 JBL thinking I would notice much difference. But damn, do the 802 D3 still sound good. But are they still worth it at 8500$?
As the speakers aren't being measured here and I'm never really seeing any comparison to any other speakers. I wonder if they're somewhat comparable to other speakers within that 8-10k price range.
Can I sell them and get a similar quality speakers at 2k? Or should I keep it because I will never get comparable performance until at least 10k+.
Hey everyone,
RoomPerfect does not attempt to correct the speaker's frequency response (in contrast to Dirac), and there is no option to limit it to bass only.Okay. Do you like them more with eq only in the bass or with eq in all frequencies?
OP did not mention that he is running out of steam. Lyngdorf TDAI-2170 can handle these speakers without issues:Price is definitely good. But your amplifier is not up to the task to drive them. Try something like Bryston or McIntosh, these are two classical parings to B&W. And you will need a lot of room treatment to me them work in medium size or smaller rooms.
But what about the synergy, did you think about that?OP did not mention that he is running out of steam. Lyngdorf TDAI-2170 can handle these speakers without issues:
It was.I’m not sure if that was purely placebo.
www.audiosciencereview.com
Not bi amping, using the SDA as a power amplifier while the TDAI is doing the processing, no amplification.It was.
Bi-amping 101
This article provides a quick look at how bi-amplification works. The conventional scheme is to split the signal into two frequency bands before the power amplifiers that drive the speakers. The bass (LF) amp sees only LF signals and drives only the LF driver (woofer). The treble (HF) amp sees...www.audiosciencereview.com
It might be worth it to switch back and see if that really holds true.It just seemed like the TDAI wouldn't have been enough to drive it.
2170 is a nice amp but it's just barely enough for bigger B&W's (and Focals). For louder levels and bass a beefier amp is the way to go. Nowadays power is affordable so I see no reason not to have it.It might be worth it to switch back and see if that really holds true.
This goes a bit beyond my capabilities to be honest. It's always interesting, but I have no idea how to even start doing this?Unless you want to get new speakers just to get new speakers, there are a number of things I would do first.
1) Have you tried playing around with the Lyngdorf voicings (parametric EQ) and/or tone controls?
2) Have you measured the response you're getting at the listening position? As I said earlier, RoomPerfect does not try to correct the speaker's response, but you could do so with a customized voicing after making measurements.
