B&O Beolab 20 Speaker Review
Rate this speaker:
    Votes: 132 47.8%
    Votes: 109 39.5%
    Votes: 26 9.4%
    Votes: 9 3.3%
sarumbear
I didn’t hear them in Kal’s room.
If that 10+dB boost at around 15Hz is a room mode then why the automatic DSP haven’t corrected it? What is the point of all that palaver if your FR deviation in the audio range is 25dB?
digital signal processing (DSP) to correct the room's acoustic. However, it differs from conventional correction solutions in applying not just individual filters for the Left and Right speakers, but also filters to correct the speakers' summed (Mono) output and the difference between their outputs (Side).
Purité Audio
Industry Insider
Barrowmaster
London
Ask whoever set them up in Kal’s room.
sarumbear
It was B&O!
I was visited by B&O's Tonmeister, Geoff Martin, who confirmed that the setup was working properly. His task was then to calibrate the Active Room Compensation, or room EQ, using his PC connected to the Master BeoLab 90. You might think of it room EQ as mere icing on the cake, but sometimes it can make all the difference.
It's sometimes hard to distinguish scale online. Once we got a look at the naked beast it became apparent that the rather modest-sized woofer chamber will limit its low-frequency performance. Using/touting DSP to boost that 20 Hz region where the speaker's linearity suffers is a sin.
Yes, while rather heavy, it is a small box especially since it is cone shaped.
To whoever asked about positioning, you can't tell from the picture but I have pulled it way away from the walls. It is probably 4 to 5 feet from back wall and similar distance to side wall. The space it is in, is massive in scale (open loft with 25 foot ceiling).
heflys20
Funny looking and expensive with the performance of a speaker that's $14k cheaper... What's not to like? I feel sympathy for the original purchaser. I'm just waiting for someone to start posting how we're not "getting" it.
phoenixdogfan
Nashville
Have to wonder if the Beolab 90 is really the edge of the art design it's been reputed to be, given the disappointing measured performance of this speaker which costs a paltry $15k/pr.
John Atkinson
Industry Insider
Reviewer
+/-10dB is superb?
Note that this graph shows the Beolab 90's spatially averaged response at the listening position in "Wide" (blue), "Narrow" (red), and "Omni" (green) modes. It is misleading to say that the response varies by +/-10dB - this is explained in the text.
John Atkinson
Technical Editor, Stereophile
Axo1989
Sydney
+/-10dB is superb?
As JA said:
I suspect that the increase in level in the low bass arises from the usual boundary reinforcement in this region—KR had each speaker situated just 18" from its respective sidewall.
That was part of the description for the previous graph, but looks applicable to this one also.
Edit: well, ninja'd by the man himself, and yes, what he said. :D
fineMen
Could you name a record or two which demand a critical level at 20Hz? I would like to investigate this further. I know only very few, namely 3 records that would request for 30Hz at -6dB full scale.
All in all it might not be the driver to set limit here, but the amp.
sarumbear
John Atkinson
Thank you for your comment. It’s appreciated.
Fig.3 Bang & Olufsen BeoLab 90, Narrow mode, 1/6-octave responses of left (blue) and right (red) speakers with DSP correction at listening position.
"There are still some room effects visible—the lack of lower-midrange energy and the peak at 105Hz in the left channel—but these are mild, especially when you consider that there was no spatial averaging in this graph."
Not only there is 15dB boost at low frequencies but also +/-5dB between 200-600Hz. Spatially averaged or not there is a huge level difference across the audible range that other speaker does not exhibit
As a comparison, here are a couple of your measurements. Neither has anywhere near as much deviation.
Fig.4 KEF Blade Two Meta, anechoic response on tweeter axis at 50", averaged across 30° horizontal window and corrected for microphone response, with the complex sum of the nearfield woofer and port responses (black trace below 300Hz).
Fig.4 Revel Performa F228Be, anechoic response on tweeter axis at 50", averaged across 30° horizontal window and corrected for microphone response, with complex sum of nearfield responses plotted below 300Hz.
test1223
It looks like the Revel speakers and other stuff is quite close.
Have you tried these or other omnidirectional speakers placed more or less symmetrically in the middle of the room with a wider stereo triangle? IMHO it is worth the experience. You get ready good envelopment, which is very hard to get with any standard speaker even if you take a lot of care of the room acoustics (which most of us can't since it is still a living room and no hifi room). Even good atmos systems usually don't provide this grade of envelopment.
This is not omni directional. It looks that way but the woofer and midrange are front-firing. And the tweeter has a circular, closed back. Here is the beam width:
It narrows to 50 degrees at lower treble. And hugely narrows above 8 kHz.
test1223
Yes it is still much more omnidirectional than 95% speaker designs. As I said I don't know if that speaker can provide this but my guess is that it can bring this to the table since it is wide enough.
sarumbear
Why do you think so. Here is a comparison to a standard floor stander. What is different, other than the smooth response, that is?
Axo1989
Sydney
Rooms behaviour at 20-30 Hz for the B&O vs well above that for the KEF and Revel examples could be the explanation. I get ~15 dB boost from my room's first and second long modes (~25 and 50 Hz respectively) but things are quite different at 70-100 Hz.
LMDA1
Never thought these sounded good in the Benz's I'd be in. Always suspected they were more an "audiophile-y" company than a serious audio fidelity one.
They fixed that with the Burmester setups.
