B&O Beolab 20 Speaker Review
Rate this speaker:
    Votes: 132 47.8%
    Votes: 109 39.5%
    Votes: 26 9.4%
    Votes: 9 3.3%
Bjorn
Norway
I wonder if this speaker could be a good example of limitations of DSP and EQ? Clearly some things cannot be fixed.
The ragged response is likely primarily the result of cabinet diffraction. That's an area you cannot EQ effectively, as it would simply get worse at other angles. Not sure what you mean by limation of DSP. A passive speaker without DSP is far more limited than an active with DSP.
HarmonicTHD
Why would you say that? Just because of this one example?
Others eg Neumann KH150 clearly showed what is possible.
Rja4000
Liège, Belgium
Always suspected they were more an "audiophile-y" company than a serious audio fidelity one.
Well, they have had highs and downs.
They've been producing some very interesting hardware in the past. Innovative and performant.
Sometimes.
I remember some tangential arm turntable.
Or, more recently, the ICE Power amp modules.
Would those small resonances and jagged line be audible?
They are if a note hits them. I think that is the reason its performance is so variable, sounding good on some tracks but not others.
solderdude
The Neitherlands
Is that a dome tweeter in a small waveguide or just some injection molding thingy ?
Perhaps listening up close could unravel this mystery (to me) ?
Definitely not a tweeter/driver. It is a 3-way design.
radix
Yeh, I meant to note that as well.
B&O went wireless some time ago. I would think most customers never look in that access panel as they simply plug it in and use the B&O wireless system.
Marc v E
The Netherlands (Holland)
I'm quite surprised by the result. Not so much the frequency response, but more the resonances. B&O have an anechoic chamber and the measuring equipment. Why didn't they resolve the issues with the resonances?
Sokel
I think Ice Power is no more part of B&O,they are a different separate company for some time now.
You can tell by their new (Edge) design.
Marc v E
It's interesting to see the narrowing in the highs. The idea with the lense is to maintain wide directivity in the treble, but we can see this doesn't work that well.
If we look at the horizontal polars B&O have published themselves of the much more expensive Beolab 90 which also uses such a lense, we see the same trait.
Horizontal polar in wide mode:
And Beolab 90 in narrow mode:
I'm probably not the only one thinking about E.T. head here!
The Beolab 90 uses a tweeter array. The Beolab 20 uses an acoustic lens.
Sokel
Disappointing. Thought they would be better. I'm fan of the brand and use the MC120.2 on my TV system. https://www.beoworld.org/prod_details.asp?pid=645
Wanted to vote 'not terrible' but can't in all conscience.
This 800Hz resonance spoils everything big time,it's not only strange,it looks if like something is broken.
Disappointing indeed.
(the odd me would have them with the cloth removed,I like them more this way)
Thanks Amir!
