B&O Beolab 20 Speaker Review
Rate this speaker:
    Votes: 133 47.8%
    Votes: 110 39.6%
    Votes: 26 9.4%
    Votes: 9 3.2%
This is a review and detailed measurements of Bang & Olufsen (B&O) Beolab 20 speaker. It was kindly drop shipped to me by a member and costs US $15,000.
You expect out of box industrial design from B&O and that is what they deliver. The Beolab 20 is an active, 3-way, sealed design. The woofer and mid-range are behind the cone cloth. The tweeter is unusual in the way it fires up into an acoustic lens of sorts:
The back side is made out of some kind of rubber (?) with a panel that removes to expose the inputs, power, etc.:
I was disappointed in the look, feel and component selections there. As you may be able to see, there is dust on the lower shelf. The RCA connectors are the ultra-cheap looking tin coated ones instead of gold. The dip switches work but again, don't give the feeling of luxury. On the positive from there is support for wireless streaming in the form of WISA (but sadly not bluetooth). And digital input. This requires synchronization between the two speaker which they are doing with a toslink out to the other speaker. And then you would need some kind of volume control.
The measurements you are about to see are generated by the Klippel Near-field Scanner (NFS). Critical measurements are made anechoic with others being in-room. Temperature of the measurement room was rather low at 57 degrees F. Reference axis was that of the tweeter. Speaker was tested with he switches as you see with the Free-space selection. Even though I have two speakers, listening tests per research was performed using a single one.
Beolab 20 Measurements
Let's start as usual with our anechoic, CEA-2034 standard compliant frequency response measurements:
Wow, I don't think I have measured a speaker that goes essentially flat down 20 Hz and especially one in this compact size! That is the good news. The bad news is that there is fair amount of variations, resonances and disturbances along the way. The plurality of these will make it difficult to develop an EQ for this speaker. We can see clues to some of these issues in our near-field measurements of each driver:
Note that I could not visually located the mid-range so that response may be approximate. But the woofer is not and we can see resonant peaks. The mid-range's upper spectrum also has a lot of ups and downs. And there is peaking in the tweeter as well. I am assuming DSP is used in this speaker. If so, surprising that they have not attempted to quell these variations with better crossovers and filtering.
Back to CEA-2034, here is our early window response which again, doesn't look all that nice:
So naturally our combined predicted in-room response has issues:
There is large variation in dispersion of the speaker:
I was surprised and disappointed to see the super narrowing of the tweeter response above 8 to 10 kHz.
Vertically we have a very messy situation:
So much going on outside of our solid areas indicating secondary diffraction and such.
Distortion is not bad at 86 dBSPL but gets worse at an odd position in response:
I looked at woofer response and it was not the cause of the peaking around 800 Hz. Instead, it seems to be the midrange that is complaining:
It is also responsible for multiple resonances up high which we saw in near-field response of the driver.
Waterfall display shows resonances:
Finally, here is the step response for fans of that measurement:
Beolab 20 Speaker Listening Tests
I placed the speaker as you see in the intro shot in my main listening room. I had just tested a $500 speaker with the famous Stevie Ray Vaughan track, the Tin Pan Alley. I expected it to sound even better on Beolab 20. Instead, I found the experience the other way around. It sounded dull and unexciting. So I skipped that and went to my standard reference tracks of female performances. Fidelity was improved here with a bit more bass presence that I typically hear from small speakers. As I progressed through tracks, I realized that the Beolab was activating my room mode at 105 Hz so started to EQ that and made more corrections after that:
As I noted in the review, building an EQ by eye is going to be difficult and it was. I *think* I made an improvement but I am not sure it translated across all tracks. The highs needed a boost so I put in the shelving filter initially at 2 dB but had to knock that down as it was a bit bright. A less lazy approach with multiple filters would have avoided that perhaps.
The initial filter set did not have that high-pass filter. I jumped into my tracks with sub-bass (< 30 Hz) content expecting great performance. The Beolab played this range but what I heard was quite distorted and odd sounding. The above filter reduced that some but what I was hearing was still abnormal and I preferred not having that sub-bass than what I heard. We see high distortion in bass frequencies in the measurements confirming what I was hearing.
On the positive front, high-pitch notes at times resonated around the room in a way I had not heard before. They would sparkle against different points in 3-D space which was a nice effect! So that tweeter design is doing something.
Overall, the response as I noted was variable. On some tracks such as Deadmou5, the speaker sounded wonderful. But on others as I noted, it was a let down. Maybe more work with positioning and filtering helps.
B&O is known for innovating in design department when it comes to looks of the products. At the same time, they have extensive engineering and research facilities. The latter gave me hope that they could tame the restrictions that the industrial imposes on design. Alas, it doesn't seem to be the case here. I think driving the speaker to have 20 Hz response but with distortion is unwise. There are a lot of resonances and interference patterns between the three drivers which I think could have been dealt with better. Clearly what we have is nicer than some just going for looks. But as a hi-fi product, it doesn't fit the bill quite right.
I am sad to not be able to recommend the B&O Beolab 20 speaker. Performance is too uneven given the very high cost.
So much money for such poor performance! They look cool
It has been said that "Beauty is only skin deep."
Target audience will never see the back of this speaker; as they will have consultant-minions that will most likely perform the required set-up and interconnection.... probably using $500 cables to attach to those ultra-cheap RCAs...:confused:
The house-cleaning personnel will take care of other mundane tasks as dusting the (back) skin that the owners will never see.
Postman Panther as is. Golfer Panther as art-form.
Haha! - I bet you (sadly) are right about where these start their life.
I look the used prices up on HiFishark.com and these 20's go for 2.700 - 4.700 USD in Scandinavia. <--That's a lot of damage! :oops:
Well, B&O have never been great value in terms of $ for performance... but well nigh unbeatable in terms of $ for looks and convenience/lifestyle (if you buy into their ecosystem... as stand-alone not so much!)
I would love to see some measurements of the Beolab 1 and Beolab Penta... they are getting long in the tooth now, but as a result there may be bargains out there, and I think they would make excellent full range surround speakers for the DL-ART era...
Question: Was it tested as it was positioned in the photo at the top? If so, why was "free" selected on the settings?
What do you mean by "tested?" If you mean measurements, no, not at all. If you mean my listening tests, yes. It is 5 to 6 feet away from the wall. That is neither a fit for wall or corner, both of which require being very close to either.
Their early hybrid colour TVs were sensational. No compromise design. Blew away all comers in 1971. My grandad bought us one, A Beovision 3200, when he moved in with us after grandma died.
I need help:
How do you give ginormous kudos to a CFO, when he is willing to take time from his otherwise busy schedule to come back and answer trivial questions (like mine)?:oops:
Their old TV's were very good and the remote controls were solid. We had two models and a VHS player in my childhood. The interior in the TV's was from Philips. No other TV's back then could compete in sound quality and anti-glare.
I can't help but wonder how much better these speakers would have measured if Amir had at least used some PS Audio electrical cables...
For me no amount of set-decoration of beautiful photography can make those speakers look appealing. Each speaker resembles someone who got stuck trying to set up their pop-up tent from the inside, and they're struggling to get out.
^^ made me laugh.
but... but... but... my only viable option is to build myself a 'mission' (arts&crafts) style dog-house, that will match the rest of the house decor!
The wooden-slats of the rear-speakers and the TV are mission-esque; IF it matters much to keep peace and harmony.:)
I only have 00.15% voting power regarding W.A.F. but I am 100% for a hidden TV.
OT? Would such a large room cause echos (modes) that cannot be EQ'd?
Those I remeber. Not those. (is it true that that tweeter is rather fragile?)
But maybe my memory is failing me and I'm conflating that speaker and tweeter with the one this beolab is using, and Radio Shack never used it.
Haha, whereas the Beolab 90 represents the tent set up properly? I once had a tent that looked a lot like that now that you remind me.
Edit: had to unhide a miscreant to see that room: you were actually complaining about the 90 not the 20. Oh well, there's no accounting for taste. :p
Nothing would sound good in that room regardless of how good the speakers are unless listening nearfield. Acres of hardwood flooring, huge windows, almost no furniture or wall decoration to diffuse/damp reflections. Bass (room modes) are easier to control in a big room if you have the subwooferage but everything else would be a mess of reflections in that room as pictured.
The standard B&O rooms, as shown in all their advertising and websites, are universally examples of the worst possible environment for Audio!!!
Sometimes this place degenerates into a miserable pile of argument ad lazarum.
I'll take the TV, the speakers and the room, no problem. :)
