PristineSound
Per ChatGPT BelowHave you asked ChatGTP?
Prompt:
"In high fidelity audio equipment, a power cable doesn't carry audio signal. Why do folks say that changes the sound? Please compare their answer with proven science. Please do not use ASR as your source."
ChatGPT's response:
Short answer: a power cable doesn’t carry the audio signal, but it does feed the circuitry that ultimately creates the audio signal. So in principle it can influence sound—but under normal, well-designed conditions the effect should be negligible to nonexistent. The gap between what people report and what’s supported by controlled measurements is where the debate lives.
What enthusiasts typically claim
You’ll hear descriptions like:
“blacker background”
“tighter bass”
“more air and detail”
“better imaging”
The explanations usually fall into a few categories:
1) “Cleaner power”
Claim: Premium cables reduce noise from the wall, improving sound.
Reality check:
Most modern audio gear already includes:
power transformers
rectifiers
large filter capacitors
voltage regulators
These stages provide orders of magnitude more noise reduction than any short AC cable ever could. By the time power reaches the audio circuitry, the waveform from the wall has been heavily transformed into stable DC.
2) “Better current delivery / dynamics”
Claim: A thicker or better cable allows faster current delivery for dynamic peaks.
Reality check:
From basic circuit theory (Ohm’s Law):
genui{"math_block_widget_always_prefetch_v2":{"content":"V = IR"}}The resistance of a typical 6-foot power cable is extremely small (milliohms).
The voltage drop across it—even during peaks—is tiny compared to the supply voltage.
The dominant impedance is usually the house wiring and power supply design, not the last few feet of cable.
So unless the cable is defective or absurdly thin, it won’t limit dynamics.
3) “Shielding against interference”
Claim: Fancy cables block electromagnetic interference (EMI/RFI).
Reality check:
EMI can matter—but it’s far more effectively handled inside the component (layout, grounding, filtering).
A properly designed power supply already rejects common noise (high PSRR—power supply rejection ratio).
External cable shielding can help in extreme RF environments, but that’s not typical home listening.
4) “Directionality / metallurgy / cryogenic treatment”
Claim: Cable materials or direction affect electron flow and thus sound.
Reality check:
AC power alternates direction 50/60 times per second.
Copper conductivity differences at audio-relevant frequencies are negligible.
No established electrical theory predicts audible effects from these factors in power cables.
What controlled science says
When tested under controlled conditions (level-matched, blind listening, proper controls):
Differences between competent power cables are generally not detectable
Measured differences (if any) are typically:
far below audible thresholds
buried under the noise floor of the system
Key engineering principles:
Power supply rejection isolates audio circuits from AC variations
Filtering and regulation dominate noise performance
Last-meter effects are negligible compared to upstream wiring and internal design
Why people still hear differences
This is the interesting part—and it’s not about dismissing people, but understanding perception.
1) Expectation bias
If you expect improvement (especially after spending money), your brain often finds it.
2) Sighted listening
Knowing which cable is in use changes perception—this is well documented in psychoacoustics.
3) Small uncontrolled variables
Slight volume differences
Replugging connections
Time gaps between comparisons
These can create perceived changes that aren’t from the cable.
4) System interactions (rare but real)
In poorly designed or edge-case systems:
ground loops
RF susceptibility
inadequate power supply design
A different cable might slightly change behavior—but this is fixing a flaw, not revealing hidden fidelity.
Where both sides have a point
Audiophile intuition (partially valid):
Power quality can affect audio equipment
Noise and grounding matter
Engineering reality (stronger support):
The power supply design is what determines susceptibility
A normal, spec-compliant cable is already “good enough”
Improvements from cables alone are typically below audibility
A useful analogy
Think of it like fueling a car:
The engine (power supply) determines performance
The fuel line (power cable) just needs to not restrict flow
Upgrading the fuel line doesn’t make the engine more powerful—unless the original was faulty.
Bottom line
There is no solid, reproducible scientific evidence that standard, properly built power cables change sound quality in normal conditions.
Most claimed differences are better explained by perception, bias, or system issues, not the cable itself.
If a cable does make a difference, it usually points to a problem elsewhere in the system.
If you want, I can walk you through a simple blind test setup that lets you evaluate this objectively with your own system.
