AXPONA 2026: Estelon & Vitus $1.5M Audio System
Yes, you read that right. This grand system cost a cool US $1.5 million dollars!
At least it kind of looks it!
My favorite:
Taiko Audio's Music Server (high-end Windows server costing more money than you probably have):
It was being played in the Reel to Reel. Speakers were so far separate and toed out that there was a big hole in the middle. Mids and vocals did sound good.
Highs were nice and clear.
It's always fun to watch the upper part's height be adjusted by RC.
They do kick, but not as much as their size would suggest.
(room and material depended of course)
Why do so many speakers at Axpona have little to no toe-in, or almost reverse toe-in by the looks of the pictures?
My experience from shows is to do the opposite, MORE toe-in than I'd usually have. This to blend the channels more and get a wider sweetspot (sounds better for more people).
Because Amir is using a 16-35 lens. That causes wide angle distortion. The speakers might be pointing straight ahead, but if you stand between them and use a wide angle lens, the speakers will appear to be toed out.
I know this is picky, but surely they could have came up with something more imaginative to call their flagship speakers other than 'Extreme'? Sounds like a soft drink.
Systems setup by people who spent their time selecting the best power cord for the show.
My favorite:
Hi there, I’m Aldo Filippelli. These are photos from my room at AXPONA. For those who don’t know me, I’m an acoustic engineer that became a speaker designer, who was also one of the top car audio system designers and installers in the 80s and 9@s, then decided to become the distributor of Dynaudio in 1995. Since then, I’ve done so many things in and outside of the audio industry. In 2020, I decided to convert my consulting company into a global sales representation firm for various high end audio companies.
Regarding the room at AXPONA, thank you for sharing here in the forum! Much appreciated!
The speakers were actually toed-in about 12 degrees. Because of the shape of the speakers, lighting in the room, and general visual perception I can understand why you would have assumed there were toed-out, which indeed was not the case.
After exhibiting in that very room, which is 32 x 32 x 30 (a cube) and has terrible absorptive aspects, I had to spend much time to design various acoustical solutions to “fix” problems in the room while improving sound stage, imaging, and presence, as well as addressing numerous bass and resonance issues in the room.
The speakers were setup for the middle of the first two rows of seats while allowing a similar but slightly less ideal for the rest of the seated listeners. The imaging was rock solid and realistic in height, depth, width, and layering. However, it did depend on the selection of music, your seated location, and limited or no talking and distractions. The Haas effect was in full accord and assisted by strategic placement of diffusers, absorbers, and hybrid acoustic treatments in the room, including the number of bodies and their location. Know for certain that the imaging and staging were absolutely precise and many said were perfect, but again based on what I just said. I spent many hours dialing the system in with the guys from Scott Walker Audio and we were all extremely happy with the results.
The subs in the rear of the room were used for bass cancellation as proximity subs, with levels turned all of the way to their lowest setting, crossover low passed at 40Hz on one and 48Hz on the other, and phase in each adjusted independently to force cancellation at specific points in the room, namely the center listening positions. These helped reduce peaks while improving phase and decay times. It’s a trick common in studios and some theaters.
If you have any questions about the room and setup, please contact me. Thank you.
Question: on a system this expensive, does the company provide the gear? Or do you have to buy demo gear to show?
Great and logical question. In this particular show, Scott Walker Audio donated the speakers, Vitus electronics, tape deck and tapes, ART devices, RevoPods, Taiko streamer, VS Subwoofers, and Seismion active bases all from stereo owned demos. I provided the racks, cables, acoustic products, and other items. The manufacturers provided personnel for support and marketing assistance.
It’s a different situation for every show.
Haa...The eternal sentence: " The room had very bad accoustic, it was a disaster..." Meaning by it: Buy it, it can only sound better at your home
I think I have heard this sentence everytime I visited a HiFi show, especially in Münich. A very very poor argument imho
That’s a bit rude innit?
Specially as @aldolovesmusic seems to have gone to great lengths to explain and detail that rather than using “bad room” as an excuse they did something about it.
In the case of the room I rent at AXPONA and have no choices available otherwise (12-15 exhibitors deep in lists for better rooms), Schaumburg D is a ballroom with movable walls that are using super thick absorption and fabric covers with the intent to solely absorb sound above 250Hz to lower noise levels between the multiple ballrooms sharing common walls. Then the moveable walls resonate. There was a 22dB resonant peak at 35Hz-38Hz because of the walls. It would take many guys pressing on the walls constantly to help lower measured resonance in the room. Combine this with a cube shape and 2000 resonating glass balls on the massive chandeliers above.
I’m an acoustical engineer. I had to spend the past five years in that room taking hundreds of measurements, experimenting with multitudes of bass traps and acoustic devices, and multiple system designs and placements of the speakers relative to the room. Since 2024 I had come up with a unique speaker placement offset that drastically helped reduce bass mode and comb filtering problems in the room (left speaker 6.5’ from the left wall and the right speaker 12.5’ from the right wall and about 31% into the room from the front wall.
However, it’s the selected diffuser hybrid and absorber panels I placed in the room in specific locations that greatly improved overall performance and especially Haas effect propagation and perception.
We only have 24 hours to move-in, setup, and start the show each year. If we had a week in advance and were allowed to keep systems in a room long term to use and continue to tweak, like at your home or in a dealer showroom, then everyone would have much better overall sound for sure. This is the truth of the matter. So after 5 years and many experiments and simulations throughout the year, I finally have helped overcome the majority of acoustic issues in that room and with that system. Change the system and the acoustic design and placements all change.
Very creative!
Imo the sound was very relaxing in your room. Not that such opinions carry any weight around here, but I would have been more than happy to "camp out" in your room and just enjoy, except that I was on a "mission". I did camp out for a while in the Estelon room at the Florida show. Were you there?
Hi Duke, thanks for your kind words and comments. The sound was my taste, which isn’t for everyone. It was indeed relaxed, but hyper detailed and dynamic with life-like and live transients with fast decay, big soundstage that was deep, wide, and tall, and layered in a 3 dimensional presence. Those Crystal Cable Infinite Dream cables were key to get hyper detailed sound with fast transients that were also presented in a relaxed and luxurious way.
I was at FLAX in Tampa. I setup the Forza speakers in that crazy room for House of Stereo and Estelon. Most people didn’t know, but that room is 53’ deep. I had the speakers 19 feet from the front wall and had the drapes placed just 5 feet from the drapes. Since the room was so long and only 16’ wide, it was necessary to setup the speakers this way to get proper bass energy and phasing at the first room for the listener area. However, the second row was 6dB up at 40Hz, back row 12dB up, and 18dB up if standing near the rear wall.
