- Thread Starter
- #21
No yeah I don't think anything is wrong with the Pioneer, just its digital section which is believe is the DAC isn't that great, and in my experience not all really sound the same. As I mentioned, a good external DAC makes pretty obvious sound difference to my ears on this AVR. That's what I'm bypassing and there is audible difference to me... So I don't know. EQ and stuff is all off, running in Pure Direct mode in each scenarioThere is nothing wrong with your Pioneer, except you may have an eq enabled or something like that. A newer receiver will not sound better, with the caveat that modern room correction might give a better performance. I am not familiar with Pioneers MCACC.
All DAC's and amplifiers sound the same. Room correction and speakers makes a huge difference to the sound.
Room correction made some difference in my room, but that doesn't affect what I'm referring to. The MCACC isn't bad isn't that great either, I used it and additionally fine tweaked the standing waves, it took me a while to get the best out of it
For speakers I can't complain, I have Luxman Ocean Four and I'm very very pleased with them. 25-22kHz with 25Hz at f6 and 31Hz at f3. 92dB sensitivity, 90W continuous power. They weigh like around 50kg each or ~100lbs. Compared them to a bunch of other speakers and found them to be the sonically almost the same as the Sonus Faber Olympica Nova III, at the very least 95% there to my ears but are 1/3 the price. The Fabers had slightly more detailed and crisper top end
