AVR Buying Advice: Mixed Setup (Piega L/R, MB Quart Center) – Which Sound Philosophy is the Best Match?
Bruschnik
Hello Community,
I am facing a decision regarding a new AV Receiver and am seeking recommendations for my current and future 5.x setup.
Since the models are technically very similar, I am looking for opinions on their sound characteristics and which would offer the best synergy with my speakers.
My Expanded Setup (5.x)
* Front L/R: Piega Classic 7.0 (4 Ohms, 91 dB)
* Center: MB Quart Alexxa (4–8 Ohms)
* Rear L/R: Piega Classic 5.0
* Setup Goal: Full 5.1/7.1 system.
* Room Acoustics: Standard living room, non-optimized.
> Important: Due to the combination of Piega (L/R/Rear) and an MB Quart Alexxa Center, clean sound matching (timbre matching) by the receiver and the room correction system is particularly crucial.
✨ My Priorities
My usage is very specific, which makes the choice of sound philosophy important:
* Audiophile Music (Stereo, 60%): I am looking for a musical, full-bodied, and flowing sound that gently refines the highly detailed Piega AMT tweeters and enables fatigue-free listening.
* Movies (40%): High priority on clarity and dialogue intelligibility, especially at moderate/low volume. The sound should still feel full and voluminous even when played quietly.
❓ My Receiver Selection
All models are in a similar price and performance class. I have pre-sorted the list based on their most important characteristics:
| Model | Main Advantage (Sound Philosophy) | Key Feature (Technology) |
| Marantz Cinema 50 | Warmest, Most Musical Sound | HDAM Modules (Preamp) & Audyssey XT32 |
| NAD T 758 V3i | Audiophile Purity & Modularity | Dirac Live (Best Room Correction) |
| Onkyo TX-RZ50 | Precision & Dynamics | Dirac Live (Excellent value for money) |
| Yamaha RX-A4A | Clearest, Most Analytical Sound | YPAO-R.S.C. (Proprietary Calibration) |
| Denon AVC-X3800H | Most Neutral All-Rounder | Audyssey XT32 & Best HDMI 2.1 Feature Set |
➡️ The Core Questions for the Community
* Timbre Matching in 5.x: Which receiver (Marantz, NAD, Onkyo) is best suited to balance the tonal differences between the Piega and the MB Quart Center for a cohesive front stage?
* Music vs. Correction: For my priority "audiophile music," the Marantz (HDAM) seems the obvious choice. However, is Dirac Live (NAD/Onkyo) not the more important factor for overall sound precision in a non-optimized room?
* Listening Experience: Has anyone heard a combination of Piega speakers with one of these receivers and can offer a synergy recommendation?
Thank you very much for your input!
In my experience, all competently designed modern amps/AVRs sound indistinguishable as long as they’re not pushed beyond their limits. So I wouldn’t put any weight on what is referred to as “sound philosophy” in your list — that’s largely marketing language LLMs tend to pick up.
What does make a substantial difference, though, is room correction and proper subwoofer integration. That’s where you will see real, measurable improvements, especially in a non-optimised living room. Because you mainly listen to music, I’d also consider support for Auro 2D/3D. It provides a mostly natural and coherent upmix for stereo content — in my experience, more so than Dolby Surround or Neural:X.
FWIW, I use a Denon X3800H in a modest 5.1 system and couldn’t be happier with it. You can use it with @OCA ’s excellent (and free) A1 Acoustica / A1 Express room correction, which many consider superior to Audyssey XT32 and at least on par with Dirac Live Bass Control. With an X3800H, you also have the option to upgrade to Dirac ART later. And it supports Auro 2D/3D.
As far as I know, the Marantz Cinema 50 is essentially the same platform as the Denon X3800H, just with a different exterior and a higher price. So unless you really prefer the Marantz aesthetics or UI, I don’t see a technical advantage. (It seems to be an example for what economists refer to as "price discrimination" to extract consumer surplus.)
Regarding NAD and Onkyo: both offer Dirac, but I would double-check which Dirac version they include by default (full-bandwidth vs. limited; does it have multi subwoofer integration?). That matters far more than any supposed “warm,” “analytical,” or “musical” signature.
I may be biased, but my bet would be on the Denon X3800H. Good luck and have fun.
Thank you very much for your detailed description and your experiences. I still had the question of whether one can hear a difference compared to the x4800h. Is this more audiophile than the x3800h due to the modular power amplifiers, the shielded transformer, and the better signal preparation, or is that so minimal that it is negligible?
I doubt one could hear a difference between the X3800H and X4800H. Both measure cleanly enough to be audibly transparent in normal use. If you look at @amirm ’s reviews, the X4800H does measure better — but the X3800H is already beyond the threshold where further improvements translate into audible differences.
So the choice really comes down to whether the extras of the X4800H matter to you — if I recall correctly, these are:
i) nicer build and chassis,
ii) the dual-line display,
iii) “Made in Japan”,
iv) negligibly higher power, and
v) improved measurements.
If you're not willing to pay for these features, the X3800H will perform identically for all practical listening purposes.
