Ok, that's just funny right there. Made my day.
My crossovers are set to 90Hz for the left/center/right, and 110Hz for the surround, rear surround and heights (7.2.4 system)
The speakers in the bed layer are all kits from DIY Sound Group (now Cinergy Audio). The left/center/right are these:
Denovo Audio, Elusive 1099 speaker, DNA-205, SEOS waveguide, speaker kit
www.diysoundgroup.com
Even though each speaker up front has two 10" drivers for woofers, these things start to roll off at 70Hz so a subwoofer is definitely required.
Quick pic of the front wall. Not a dedicated Home Theater but my wife has let me get away with quite a bit with this room
Subs are all DIY. "My name is James and I have a bass problem". They just kind of keep growing.
But I have discovered that the more cones/displacement you have, the less power they require to reach a certain SPL and the less distortion (less cone movement required). That's true, just not something that I keep telling myself
So up front are two 21" Eminence NSW6021 drivers in a 6cuft sealed enclosure. The pic is of 21" LaVoce's but I just replaced them with the NSW's.
Just behind the seating (where the picture is taken from) is eight 12" drivers and two 18" drivers all in sealed enclosures setup for near-field duty across four seats.
I use three NU6000 Class D amps to drive all that. It's still a work in progress but it does make me smile.
So you can imagine my surprise when I heard this weird bass sound when playing music. I've thrown a lot of movie demos through this system and it's always held up. Plus, since it's DIY, naturally I'm going to think that perhaps I did something wrong.
No Extra Bass turned on in the Yamaha. That was actually one of the first things I checked. I never turn that on but needed to check since that would definitely explain some things I was hearing if it was inadvertently turned on.
The NU6000 amps have LEDs in the front that show if the input is clipping and they are all off (it's an LED ladder) during this "bad passage" in the song. As far as the outputs, my listening level for music or movies is -26db to -22db on the Master Volume and the subs really aren't working hard at those levels.
Does anybody have this disc by chance that they could reproduce what I'm hearing? It's Pink Floyd so I thought that everyone would have this
I will continue to check out my subs for issues; I want to measure actual voltages coming out of the AVR, in and out of the DSP, and into and out of the amps. This will give me piece of mind that it's all ok.
Beyond that, this has got to be either some voodoo going on inside the AVR's bass management since it seems that we don't know how it prevents exceeding 0dBFS after summing all of that low-frequency content, or, just a weird mistake in the audio mix from the source.
