I have a Denon x7200W - and have a couple of amplifier outputs that have issues (random distortion), so I am down to 3 pairs of power amplifier outputs that are (90%) of the time fine. I am also considering replacing the x7200W in the near future with a 3900h and it is possible I might need additional amplifier channels if I was to get a 3900h, so same question below applies to both
I thought to circumvent the amplifiers with issues on the x7200W I could get a power amplifier - so I bought a Wiim Vibelink amplifier
RCA to RCA - to start with thought was all fine when watching via Apple TV box sounded great, but then turned on my gaming PC which is used in the lounge and is connected to the Denon via HDMI, and as soon as I played any games and had a decent loading on the graphics card I got very audible ground loop interference out of the speakers connect to the Wiim. I couldn't find a fix so had to return the Wiim. I don't want to go down route of removing ground pins, or adding a feedback destroyer pro type isolator.
This has put me off buying power amplifiers to add either to the x7200W or the 3900h and I was wondering what to look out for to avoid the same issue in the future as I don't want to put any further shops out by buying then having to return
is the issue RCA to RCA ? or is it down to the individual design of the power amp to how susceptible it is to ground loops ?
Note I am using an active centre connected to the Denon - a Genelec 8030C - RCA to XLR and have no ground loop noise whatsoever
I was also previously using 2x JBL 308MKII actives for Front Left and Right - again RCA to XLR and had no ground loop noise
I'm basically wondering what I need to look out for in a power amplifier to avoid please ?
Is ground loop interference less likely to be an issue with a power amplifier with XLR inputs, even though the signal from the Denon is unbalanced RCA ?
or is it literally luck of the draw ?
I would still like to buy a power amplifier for the Denon x7200W but the above is putting me off, and a future upgrade to a 3900h is making me nervous if I feel like I need more power (most of my speakers are 4-6ohms, Polk R200s, Kef Q350s, Kef upfirers) that I could have the same issue adding a power amplifier
maybe I should just buy an ex-dem Denon A10h and then not have to worry about power amplifiers thats the other future upgrade option
many thanks for any help
