Avoiding Ground Loop Interference - what to look for in a Power Amplifier ?
Buckster
I have a Denon x7200W - and have a couple of amplifier outputs that have issues (random distortion), so I am down to 3 pairs of power amplifier outputs that are (90%) of the time fine. I am also considering replacing the x7200W in the near future with a 3900h and it is possible I might need additional amplifier channels if I was to get a 3900h, so same question below applies to both
I thought to circumvent the amplifiers with issues on the x7200W I could get a power amplifier - so I bought a Wiim Vibelink amplifier
RCA to RCA - to start with thought was all fine when watching via Apple TV box sounded great, but then turned on my gaming PC which is used in the lounge and is connected to the Denon via HDMI, and as soon as I played any games and had a decent loading on the graphics card I got very audible ground loop interference out of the speakers connect to the Wiim. I couldn't find a fix so had to return the Wiim. I don't want to go down route of removing ground pins, or adding a feedback destroyer pro type isolator.
This has put me off buying power amplifiers to add either to the x7200W or the 3900h and I was wondering what to look out for to avoid the same issue in the future as I don't want to put any further shops out by buying then having to return
is the issue RCA to RCA ? or is it down to the individual design of the power amp to how susceptible it is to ground loops ?
Note I am using an active centre connected to the Denon - a Genelec 8030C - RCA to XLR and have no ground loop noise whatsoever
I was also previously using 2x JBL 308MKII actives for Front Left and Right - again RCA to XLR and had no ground loop noise
I'm basically wondering what I need to look out for in a power amplifier to avoid please ?
Is ground loop interference less likely to be an issue with a power amplifier with XLR inputs, even though the signal from the Denon is unbalanced RCA ?
or is it literally luck of the draw ?
I would still like to buy a power amplifier for the Denon x7200W but the above is putting me off, and a future upgrade to a 3900h is making me nervous if I feel like I need more power (most of my speakers are 4-6ohms, Polk R200s, Kef Q350s, Kef upfirers) that I could have the same issue adding a power amplifier
maybe I should just buy an ex-dem Denon A10h and then not have to worry about power amplifiers thats the other future upgrade option
many thanks for any help
"I have a Denon x7200W - and have a couple of amplifier outputs that have issues (random distortion), so I am down to 3 pairs of power amplifier outputs that are (90%) of the time fine."
I'd get this unit fixed or replaced first.
When you say ground loop interference, you do means mains hum and not other noise, right?
I doubt there was anything wrong with Vibelink in terms grounding issues.
We'd need a drawing of your topology with all interconnects and devices marked to make a decent guess at the fault - rather than buying stuff, it's best to understand the root cause, or you just waste a lot of money....
Earth loops are very tricky to diagnose remotely because they have a tendency to be personal! They are effectively a consequence of your set-up, your house with your mains electricity and earthing regime and your equipment. This makes it hard for anyone to confidently propose a fix.
I feel your diagnosis is probably right - that an earth-current is flowing via your PC. PCs can be quite problematic in this regard and ASR is full of posts from people suffering the same GPU and heavy load noises as you are. You have been lucky so far, that your set-up has not had problems before.
If it's physically possible, you can sometimes minimise the issue if the PC and your audio equipment is plugged into one wall socket via a single distribution board.
Because you are using HDMI, optical isolation is not an option, but it is a good way to break earth loops. It might be worth investigating whether your PC has an optical out port. Although using this may require rethinking how your gear is wired and may require a standalone DAC or optical converter.
Other options are to try balanced / differential working. It's not a guarantee, but it can separate signals from earth. RCA doesn't allow a separate audio ground / reference.
In studios, everything is normally balanced / differential to minimise noise and earth loop risks. Any non-balanced gear is either run on a mains isolating transformer or via a direct injection box (transformer or electronic).
It might help to know which part of the world you're in, since earthing practices vary by country. Also, is all your equipment earthed via 3rd-pin or is some of it type 2 or double -pin only gear. Do you have a turntable etc.
We'd need a drawing of your topology with all interconnects and devices marked to make a decent guess at the fault.
thankyou for your reply
the distortion seems to be related to some issue on the PCB near the rear speaker outputs - if I was to use the affected speaker outputs if the speaker outputs started distorting or going quieter (can loose half volume) - if I pull upwards on the banana plug it fixes for a while, I suspect a possible issue with a trace on one of the Denon boards relating to the speaker outputs
the noise through the Vibelink was loud enough that it was louder than the actual speaker output content and low - medium volumes. The interference/noise changed tone and loudness depending on the content of the game, as in depended on the load on the GPU
when I say interference/noise - was whining/static type noise that changed volume and pitch depending on how much load on the GPU.
I'll draw up a diagram
note the 8030C is connected to the centre pre-out RCA from the Denon - just happens to have to be a RCA to XLR connector as the 8030C only has XLR input. I get zero issues with the 8030C when gaming on the PC - I can't hear any interference/noise at all
Thankyou for your reply
Optical out is not an option (I'm not sure the board even has) unfortunately - as I use Dolby Atmos/Multi-channel PCM for games etc from the PC
Based in the UK - 3 pin 60hz/240V
"whining/static type noise"...
Sounds more like a fault than an actual ground loop to me. Could be cable or a connector somewhere, could also be the Denon.
For academic interest, check if the Denon actaully uses ground - some amps are not class 2, i.e. don't connect to ground at the mains socket (look at the power socket in the back of the Denon). UK mains is 50Hz - 60Hz is largely only used in North & Central America - but it's not pertinent.
Since the PC and the Wiim amp are class I devices, a ground loop noise is possible. However if pushing the RCA connector upward changes the noise, the cause does not seem to be a ground loop, but broken soldering of the connector to the PCB.
it's me sorry - I had 60fps gaming fixed in my head, I meant 50hz/240V
it was definitely ground loop interference I have had it before when I had my JBL 305s connected via a reasonably cheap DAC to my old gaming computer and was the exact same type of noise. I fixed that by adding in a Behringer HD400 Hum Destroyer and I wasn't that bothered at the time by ultimate sound quality (I'm not sure if the Hum Destroyer is completely transparent) - plus it means additional cabling, etc
for that same setup when I had the money to buy a proper audio interface a Motu M4, I then connected the JBL 305s to the M4 via balanced XLR and I have had zero problems
thankyou for the reply, sorry the pushing the connector is not related to the ground loop noise it's a fault on my Denon speaker outputs and the pushing up is on the banana plug/speaker connector - hence trying to purchase a power amplifier or 2 to use instead of the faulty power amplifier/speaker outs for a couple of the channels on my Denon
I guess what I am trying to work out is the following:
Genelec 8030C - no ground loop noise, Wiim Vibelink as power amplifier - group loop noise
8030C connected RCA to XLR
Wiim Vibelink - RCA to RCA
is the RCA to RCA the issue and would be for any power amplifier with only RCA inputs
or is the susceptibility to audible ground loop noise dependent on the actual design of the power amplifier and the cabling RCA to XLR or RCA to RCA is irrelevant (they are both unbalanced)
if the latter is the case - I guess I'll only know when I connect up a particular power amplifier and its either an issue or not
I believe I could buy a "hifi" signal isolator, something more deluxe than the Behringer HD400 Hum Destroyer, but if I'm going to spend £300 odd pounds on that per stereo set of channels - I may as well put that money towards an upgraded AV amplifier once I've taken into account the cost of the power amplifier/s as well
my probably best option is just to replace the x7200w with a 3900h and be done with, I'm just nervous that the 3900h will sound as good as the 7200w (I know the EQ on the 3900h is much better)
I had gone through a lot of AV amplifier before I was happy with the x7200W
I'd originally had a Pioneer AX10Ai which I loved, but not having HDMI was an issue
I tried a Yamaha, a Denon 4311, and another Av amplifier which I can't remember but none sounded as good as the Pioneer - it was only when I bought the Denon x7200W that I was really happy with the sound, and I'm not sure if that is down to the power amplifier stages of the Denon or the AK Dacs (has 8x AK4490 DACs - same as the Denon x8500H) or just a combo of it all
I just wonder if the 3900h will be a downgrade
Yes.
The issue at hand is that every to mains connected device has some 'leakage' current in its power supply. Sometimes this is even orientation dependent (figure-8 or non earth pin wall socket). Rotating such a plug could lower (or increase) the leakage current.
That leakage current (not voltage) wants to 'flow' back to 'ground. The problem is that 2 devices with a different leakage current will find its way to 'flow' through the shield of an RCA cable.
That leakage current, depending on the resistance in its path (ground and wiring in devices AND resistance of the shield of the RCA cable) will cause a small voltage (hum or unwanted noises) that will be 'mixed' with the audio signal that is present on that cable and become audible.
As long as that unwanted voltage (current through the shield) is low enough that you can't hear it there is no issue. Only when it is high enough and becomes audible it is an issue.
More connected devices can mean more or less unwanted currents between audio devices. Even the shield resistance of an interlink cable can matter.
A device may not be well designed internally for this exact issue but may be fine otherwise.
This is NOT tested in audio measurements so you will only find out when certain devices are combined.
The problem with RCA is that the shield is connected to audio-ground and thus carries both the signal AND the unwanted current.
The advantage of balanced transmission is that the audio-ground is not really used (only hot and cold signal) and thus unwanted currents can flow through the shield and thus not enter the audio path.
Problem solved (currents becoming audible). The currents are there but do not enter the audio path.
The moment one uses XLR to RCA conversion cables the advantage balanced has is gone as the ground is used again for signal and leakage.
As @MaxwellsEq already mentioned it is hard to diagnose and sometimes can be harder to solve.
In most cases the culprit for the highest 'leakage currents (ground loops) are PC power supplies via audio out or USB out to a DAC, sometimes TV's or other devices also do this.
Find the culprit by connecting the last device only (the amp connected to the speakers only) without anything connected and step by step add another device and seen which one causes the issue and go from there.
Yes.
That leakage current (not voltage) wants to flow and the problem is that 2 devices with a different leakage current will flow through the shield of an RCA cable.
That current, depending on the resistance in its path (ground and wiring in devices AND resistance of the shield of the RCA cable) will cause a small voltage (hum or unwanted noises) that are 'mixed' with the audio signal on that cable and become audible.
More devices can mean more or less unwanted currents between audio devices. Even the shield resistance of an interlink cable can matter.
thanks very much for the detailed info - ref the culprit so to speak, I tried that and its definitely the PC that is the source of the issue
Denon on its own, no ground loop noise from the speakers connected to the Vibelink
same with Apple TV connected up to the Denon and watching content
only an issue with PC connected to Denon and games putting load on GPU - its a 9070XT it draws around 300W under load
BUT it doesn't affect the Genelec 8030C and didnt' affect the JBL 3080MKIIs that were connected to the Denon either
That has to do with how the devices are made internally (how the ground signal is handled/created).
That, however, does not matter as the issue is there and needs to be solved and modifying gear or using other gear is not an option or an unwanted option.
The solution here (most likely) is to use a real USB isolator between the PC and DAC.
Did you try the Vibelink without trigger cable and are you using a mono cable?
I had ground loop issues from that before. Wasn't source dependent though.
in answer to the above and thankyou for all of the replies
Vibelink I tried with and without trigger cable
noise pickup only occurs when the PC is turned on and the GPU is under load (as in games, video playback etc)
USB is not an option unfortunately, as I use the PC for gaming etc, which requires multi-channel audio, Atmos etc - hence has to be HDMI
PCs very often cause audible ground-loop noise currents because of the huge currents (at low voltages) running through their ground planes/wires, and the 0V terminal is galvanically connected to the PE wire. Then a tiny portion of these currents does not go straight to the 0V terminal of the PC PSU via the shortest path, but goes across the audio shields to a component with PE wire, and via the house PE wires and the PC power supply cord to the PSU 0V terminal. If these currents mix up with audio-path return currents (every signal is a current), they often become audible. Then you can hear mouse moving (USB controller, GPU work), keyboard keys (the same), HDD working, CPU power states switching etc. No matter how good the attached audio device is, the currents get mixed in interconnects.
Of course a balanced connection fixes that because the ground currents (while still flowing through the balanced-cable shield) do not become part of the audio currents.
He connects the PC to the Denon using HDMI which is TMDS (balanced signaling).
Yes - I lost sight of this.
Is your PC and the Denon on the same ring circuit?
When you are getting noise from the PC, does unplugging the Genelec 8030C make any difference? Is it on the same mains ring too?
But what counts is the analog audio connection. HDMI cable transfers ground-loop currents via its shield + gnd wire, and these mix up with return-path currents of single-ended analog interconnects, if the connected analog device closes the ground loop.
