bennybbbx
A small note on the discussion of the superior "transient" behavior of the Avantone speaker.
The unbalanced frequency response and the FR in shape of a bandpass filter means that the group delay (as a measure of transient behavior) of the Avantone speaker is not particularly good, especially in the frequency range below 500Hz.
A normal 2-way speaker shows better GD below 500Hz and can keep up well above (both are well below the perception threshold).
2-way speaker (blue curve - FR) versus MixCube (red curve - FR) - FR and normal phase
Group delay 2-way speaker (green curve) versus MixCube (black curve)
On top of that, the MixCube speaker has a lot of (very likely) slow decaying resonances that ruin any good transient behavior. According to Amir's CSD, the resonance around 5kHz, for example, needs more than twelve oscillation periods until it is damped by 25dB. The 7kHz needs even more oscillation periods...
there should know with the phase is the same ( or much more) as with EQ. the lower the change per octave the less can it hear. and the avantone have a smoother slope. the hifi theory say 1 cycle group delay is good enough. Did other not hear very much with 1/3 cycle delay (120 degree pahse shift) the kick sound not good ?. later i paint a slower slope and it sound better. at sec 50 i use 360 degree phase shift(1 cycle ). I hope then can hear even more phase problem . this is video so you can see me paint and hear. a abx compare is not need because the diffrence so much
