ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 5,454
- Likes
- 3,267
I disagree. They would have easier time if they could manipulate signal in digital domain but they couldn't. It whose pioneer 8 bit Zilog time and 16 bit only starting to emerge (timeline studio variant started to be popular) and took some more time to audio card's even start to appear. I really don't get how it's so hard to understand that boost about two audible levels in real content or 3 dB in upper high mids and extended to highs where second harmonics for most stuff is (vocals and most of instruments) helps you focus on them bringing them in front. Its crowded area and you really need to do it good so that nothing doesn't jump out to do layers and separation between the stuff. Doing something like that is fatiguing by it self and for the ear's and it will always be to the excessive use of auditory system along with brain. Getting that done right will definitely help the material sound better on pretty much any speaker (represents most of information, most of the work and after all is range every speaker will actually cover relatively good). Of course you remember what it is and after you are done you adjust level's back and listening to something that you would consider as very even balanced and full range or simply on console GEK already knowing what NS10M's does. It whosent great or even good for listening to music obviously but put to back wall and with tone control's +2, -3 it whosent bad at least in the range it covers (bit extended in the bottom). It's not broken or bad when good done DSP processing actually even rivaling some of the best to day near field actuve DSP-ed studio monitors with same additional digital processing with applied technical limitations regarding design.I am not trying to make up fantasies about you are saying. I am struggling to understand your standpoint, and when I ask for clarification you get aggressive and/or defensive.
So instead of claiming anything about your opinions, I will try to state MY opinion, and ask if you agree.
I am of the opinion that the engineers who says that the NS-10s work great for them to identify problems in the mix in a fast an reliable way are probably correct. They have learned to know and understand it in such a way that it is an effective tool for them.
I am also of the opinion that they would identify problems in the mix in an even faster and even more reliable way if they had better monitors. Do you agree, or disagree?
Did Yamaha do measurements and proper engineering? Yes they did even in those days, NS1000 pretty much stand's as what they were able to achieve. As a matter of fact they where very aware of the room and tried to focus more on that aspect by design. The NS10's are now old and pretty much in garbage condition, there are far better regarding out of box FD and supposed coverage monitor's today even in mid budget category and you pretty much can beat a heck out of signal on modern DAW's that it's in the most cases limited by tone/mixing master imagination and stubbornes and much more able to address the elephant in the room (room modes). So there is absolutely no need for something like those and no better speakers alone don't make the difference it's still; hard work, a bit of talent, motivation and experience does help.
