ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 4,562
- Likes
- 2,702
If you're precious KH or Genelacs score the same or worse to NS10M's both paird with two closed enclosure Genelac or KH 10" sub's and EQ-ed still having considerably worse time domain how are they better in any regard? Sure they sound better on their own then NS10M's party because they are already EQ-ed (integrated DSP) but for the same reason react worse to additional EQ-ing and are harder to handle (ported design). Future more you can pair NS10's with better power amplifier (not that it will matter much especially not with KH's which already have very quiet amp) of course with much better ADC and DSP (you can't pass at least part of internal processing all do you can pass ADC by using digital input and then only down to worse DAC but really not a problem).I think that a lot of you don't get that those NS-10's (or auratones) were always used next to a very neutral monitor, to check mixes and how they translate to lo fi consumer speakers. Both the Auratone and the NS-10 are very good at that. They were rarely used for the mixing itself, but more as doublecheck, or to find a certain problem that a neutral speaker can't show so clear.
When i did some studiowork (more than a decade ago), i've used the NS-10 in combo with the Klein & Hummel o310A (ancestor of the KH310) and in an other sessien auratones with a pair of ATC 150's (if i remeber right). In both sessions you use the clean monitor in +90% of the time, but you were happy those crappy speakers were there also to have a different view on the mix and double check on translation.
I see them also sometimes in top end mastering studio's like the one of Jerboa (one of Belgians best), next to his Kii Audio Tree BXT monitors. And he uses them for the same reasons as I and most did. But as only monitor in a studio, they are worthless, i agree. The measurements that exist on the web show clearly why...
NS10M's are old and definitely deserve retirement even industry really failed to give people who really liked them improved successors (i really don't like mica cones with which Yamaha got stuck for too long time now). Actually there are so little closed enclosure design speakers today present on market that it's a shame. Open buffle design all do rare are present and they act very similar and use room instead of box but are harder to handle and separate while dominant ported designs can be good if done properly don't expect to find any of such in HiFi or home tire, some in pro tire and mostly DIY. Thing are not as simple as their may seem at first look.
