D
Deleted member 21219
Guest
The main reason is not that they don't trust their speakers, a second opinion is sometimes needed when a mixing engineer has lost the overall view of the mix (can't see the forest for the trees). This can easily happen after a long time of mixing and obvious problems in the mix are missed because of the extreme concentration on solving small details in the mix. A new set of ears can sometimes be needed to hear fairly obvious and larger overall problems with the mix.
Another way to get around this common problem is to use well-known reference tracks and listen to them regularly during the mixing session to re-tune the ears and get a "reality check". This problem got nothing to do with the speakers in use, it doesn't help if the speakers are measuring flat to not. It has more to do with acclimatization to the sound and tonality, in a similar way as a certain record can sound bright and bass-shy but your hearing gets used to it after a few songs.
I hear what you're saying, but wouldn't all this be ameliorated if equipment was standardized? Wouldn't the "reality check" become superfluous?
Jim
