I am sure I can learn a *ton* by doing this but none of it would be about the topic at hand: proper sound production/reproduction in rooms. There, our researchers have been looking into this topic for 40+ years. Not sitting there screwing around with a consumer speaker they saw in Tokyo, but the real deal. Having done that, they realize that what you all do can make or break even the best performing system we can put together. Yet you are not even aware of your role in that and problems you have created.
Here is one of those researchers: Dr. Sean Olive, AES fellow and ex president of Audio Engineering Society, a classically trained pianist and graduate of McGill University, one of the top schools when it comes to music technology:
http://seanolive.blogspot.com/2009/10/audios-circle-of-confusion.html
"Audio’s “Circle of Confusion” is a term coined by Floyd Toole [1] that describes the confusion that exists within the audio recording and reproduction chain due to the lack of a standardized, calibrated monitoring environment. Today, the circle of confusion remains the single largest obstacle in advancing the quality of audio recording and reproduction."
You see that? The single largest problem facing fidelity of music and music systems for people who consume your content.
He goes on to say:
"A random sampling of ones own music library will quickly confirm the variation in sound quality that exists among different music recordings. Apart from audible differences in dynamic range, spatial imagery, and noise and distortion, the spectral balance of recordings can vary dramatically in terms of their brightness and particularly, the quality and quantity of bass. The magnitude of these differences suggests that something other than variations in artistic judgment and good taste is at the root cause of this problem."
Still think it is a 1% problem? I think not. Here is how he nicely damns this whole process of "translation" by using crappy speakers:
"The most likely culprits are the loudspeakers and rooms through which the recording were made. While there are many excellent professional near-field monitors in the marketplace today, there are no industry guidelines or standards to ensure that they are used. The lack of meaningful, perceptually relevant loudspeaker specifications makes the excellent loudspeakers difficult to identify and separate from the truly mediocre ones. To make matters worse, some misguided recording engineers monitor and tweak their recordings through low-fidelity loudspeakers thinking that this represents what the average consumer will hear. Since loudspeakers can be mediocre in an infinite number of ways, this practice only guarantees that quality of the recording will be compromised when heard through good loudspeakers [1]. This is very counterproductive if we want to improve the quality and consistency of audio recording and reproduction."
And of course while we have been talking about the wrong speaker being used, the room is a huge problem as I showed in the Genelec study and Dr. Olive iterates:
"Another significant source of variation in the recording process stems from acoustical interactions between the loudspeaker and the listening room [1]-[3] Below 300-500 Hz, the placement of the loudspeaker-listener can cause >18 dB variations in the in-room response due to room resonances and placing the loudspeaker in proximity to a room boundary.
[....] Below 100 Hz, the in-room bass response can vary as much 25 dB among the different control rooms! You needn’t look any further than here to understand why the quality and quantity of bass is so variable among the recordings in your music library."
And the problem I told you I face in reviewing speakers (and headphones):
"Loudspeaker manufacturers are also trapped in the circle of confusion since music recordings are used by listening panels, audio reviewers, and consumers to ultimately judge the sound quality of the loudspeaker. The problem is that distortions in the recording cannot be easily separated from those produced by the loudspeaker. For example, a recording that is too bright can make a dull loudspeaker sound good, and an accurate loudspeaker sound too bright [5]. A review of the scientific literature on loudspeaker listening tests indicates that recordings are a serious nuisance variable that need to be carefully selected and controlled in the experimental design and analysis of test results."
Yet you have the audacity to say we shouldn't even be allowed to comment on this topic.
Finishing with what I have been saying (independent of their teachings, having also had a strong leg in video where standards matter for the same reason):
"As Toole points out in [1], the key in breaking the circle of confusion lies in the hands of the professional audio industry where the art is created. A meaningful standard that defined the quality and calibration of the loudspeaker and room would improve the quality and consistency of recordings. The same standard could then be applied to the playback of the recording in the consumer’s home or automobile. Finally, consumers would be able to hear the music as the artist intended."
So I suggest you put aside your one-liner arguments and take the opportunity to learn what it means to have fidelity. And how a standard is critical and necessary in achieving that. Your video counterparts are laughing at you all day, every day and twice on Sunday. Start learning this topic at a deep level. Know that such research has a ton to teach you as well. Don't sit on folklore and useless ideas. It is never too late to start doing the right thing. Do it now. Join us in advocating proper sound production and reproduction.
