AutoEQ Magic?
Good day! Can you give me the link on this site?)
Try to make my superlux HD330 sound better)
And what instructions you use?
What to do with this .csv file then?
Sure, they changed their name and upgraded to a new version but the old version is still available. I used:
Then I used that CSV on autoEQ.app
This guide is from 2019 so it's dated but it's basically accurate:
So, first 5 min, I was thinking it is better. Then, I understand that something wrong)
This measurements must not be suitable for this purpose(On the "guide" site, it is mentioned). I take it from the same site, as you do.
Sound more like voice/high oriented. Films with this EQ, very good. Dialogue in first place. But, something is wrong. Compared to my kz zs10 with harman from oratory, it is not the same, obviously.
Good expirience, but it not work in my situation)
Worth keeping track of the DAC/ amplifier dongles and/ or EQ phone apps with AutoEQ.
For the moment I know:
Wavelet
Power Amp EQ (this one quite complicated and does not work for Tidal, Deezer, also it says needs additional settings for some phone types)
Neutron HIFI DAC V1 with Nconfigurator app
Qudelix 5k
As an audio enthusiast (as in 'non technical'), I favour dongles like Neutron than can store the AutoEQ setting on the hardware dongle directly.
Wavelet
Qudelix 5k
FiiO UTWS5 has 10 band parametric EQ, although no built in AutoEq profiles. It's easy enough to configure settings there manually though
Just saw this (almost a year old post)
When using my plots you need to use a horizontal line as a target, not the one used here.
