Thanks for trying to share it, and for letting me know.The problem with Aura Engine is that trying to recommend this program on Facebook results in your account being blocked.
AuraEngine — FIR upsampler and player: 30M-tap filters on an ordinary CPU
Multistage upsampling: a 30M-tap filter at ×8 on 27 ms of CPU per second of music on four efficiency cores, no graphics card needed. Free for Windows.toxadev.github.io
"Content cannot be shared because this link violates our Community Standards." - Facebook
Yes, on paper the spot is tight. The free-field model (computed, not measured in a room) says about 2 cm of head movement already costs roughly half of the cancellation.I thought XTC working required keeping your head within a very tight MLP?
I won’t be posting links to this program on Facebook, as Facebook has placed a 24-hour restriction on my ability to post replies.Thanks for trying to share it, and for letting me know.
That message comes from Facebook's automatic link filter, not from a person reading the page. Facebook doesn't say why it blocks a link, so this is my best guess. The site is on github.io, a shared domain where anyone can host a page, and it gets used a lot for phishing and fake "free software" downloads. On top of that, the page has about 40 direct download links (installers and filter zips). To an automated filter, that pattern looks like malware distribution.
What should work for now:
- Link the GitHub repo instead: https://github.com/ToxaDev/aura-engine
- If Facebook offers "Let us know" (or similar) under the block, that sends the link for review. Sometimes the block gets lifted.
You can use this link for shareI won’t be posting links to this program on Facebook, as Facebook has placed a 24-hour restriction on my ability to post replies.
Today, they extended that restriction to 72 hours.
I will try once the restriction is removed.You can use this link for share
Multistage upsampling: a 30M-tap filter at ×8 on 27 ms of CPU per second of music on four efficiency cores, no graphics card needed. Free for Windows, Linux and macOS.aura-engine.app
so now nothing needs to be baked in? No need to run parallel libraries/playlists?it's baked into the converted file for that one setup.
Just two or three seconds from hitting play. All options enabled, except for adaptive headroom.but isn't there a lot of latency?
Loudness Contour autovariable with user adjustment of Volume level? See RME ADI-2 DAC, Schiit Forkbeard e.g. Mimir
Your quoting implies you're talking about a Loudness Contour functionJust two or three seconds from hitting play. All options enabled, except for adaptive headroom.
I don’t have any particular technical expertise. I just wanted to say that I am using Aura-Engine as a player, and it works well—especially now that it includes an equalizer and balance control. I can easily set it to 30M taps without any issues.Your quoting implies you're talking about a Loudness Contour function
AFAIK not present in the "player part" of the project, hence my requesting that.
So if not, what were you intending to respond to with
I am aware of the processing delay, not a problem for me
Thanks for spelling it out — that's a serious system. Honest answer: not today, and not something I can promise soon.Thanks. I'm planning an active system that starts with a 2.1 stream, but gets upmixed to 5.1
and then each front LCR gets xover split to 3- or 4-way "stacks", plus the mono LF channel maybe 3-4 overlapping trueSub using say MSO to wrangle room modes, total say 20ch
The digital transport side at 24-bit gets very expensive, USB not being clock sync'd, with ADAT or S/PDIF going past 48Hz just to 96kHz even with AES can mean buying double the hardware costs per channel.
Thus IF thinking what AuraEngine does isvworthwhile, this layout means cannot use the conversion to static files, must be done live on the fly each playback session downstream of DSPs used for speaker EQ, crossovers, bass management and DRC.
I'm thinking "Modularised DSP" for AuraEngine using multiple RPi5 nodes out at the downstream edges, handling say 3-8 output channels each.
Possible? all feedback welcome.
The only multi-way enclosure is a pair of OG LS50 at the FR top of the F-L/R stacks, HPF'd ~ 180Hz.it has no place inside a multi-way speaker
Clean plan — with PTP plus GPS and word-clocked DACs you've taken drift off the table, and with the LS50s high-passed and everything else single-driver, my Hybrid-Phase worry mostly goes away too. But no, it wouldn't work as AuraEngine stands today. What's missing on the AuraEngine side:Yes I figured.
A "Stereo only Critical Music" mode switch for testing then, turn off the Center, RS and mono string, F-L/R "stacks" only
Latency is NP
The rest will be co-located separate single driver boxen, MBM Couplers from 70-80Hz, then two true subs 15Hz and up, split maybe at 45Hz?
Each stack's speaker EQ, crossovers, time/phase tweaking all handled upstream so each presentsvas ifca single cohesive full-range floorstander.
An RPi5 for each stack (or x86 nodes with more DSP capacity if 30M filters prove necessary)
dedicated to your upsampling, each RT sysClock sync'd to microseconds level via PTPv2, Grandmaster disciplined to nanoseconds level heartbeat via GPS, 1PPS + 10MHz inputs
each DSP outputs via mch DACs that are BNC word clocked.
No clock drift, nor ASRC used, for sure.
This setup requires no changes to AuraEngine as it stands now?
